Panel Protection.
Submitted: Sunday, Apr 10, 2005 at 22:25
Member- Marc
Guys,
Does anyone know the name of the product that you roll/paint on your panels off the rig prior to departing, and peel it off upon return?
And, has any of you used it before. Does it work??
Thanks for the info in advance!!!
Marc.
Reply By: Rob from Cairns Offroad Training & Tours - Monday, Apr 11, 2005 at 00:01
The 3M company make a clear material called bodyguard, it is about 1.2mm thick and is invisible one applied to the vehicle. You can scrape a 50 cent piece down the side of the vehicle without damaging the paint. I had it on a 4wd for 4 years until lease expired then peeled it off easily with paint in as brand new condition underneath. Cheers Rob.
106073
Follow Up By: Member - iMusty (VIC) - Monday, Apr 11, 2005 at 08:27
That really is amazing.
iMusty
363162
Reply By: John - Qld - Monday, Apr 11, 2005 at 07:35
Scratch Pro - TJM - I think.
$60/lt last time I looked. Just don't put it on any rubber only metal.
Not sure whether it works but there was a write up in 4wd mthly last year I think which was fairly positive.
106094
Reply By: Bitsumishin - Mike (WA) - Monday, Apr 11, 2005 at 09:21
AP60 Scratchpro. i bought a can for the price previously mentioned & tried it but I think I was too stingy putting it on. To work effectively, it needs to go on thick which mean probably one can per trip so it would only be used for rough extended trips. Would also peel off a lot more easily if it was thicker. The way I put it on it was a bit like sunburn. You just think your getting a nice run & it breaks away.
106109
Reply By: Member - Andrew L (VIC) - Thursday, Apr 14, 2005 at 11:36
Hi Marc,
TPC make a roll on peel off product. Phone 0407881400 fax 07 55799515
email tpcoatings@bigpond.com.Hope this helps.
106692
