navman pin
Submitted: Monday, Apr 11, 2005 at 00:13
REX.....(Adelaide)
question can the navman pin run oziexpplorer ce ????????
Reply By: Member - David 0- Monday, Apr 11, 2005 at 07:24
Yes it can.
Caveat-
The SmartSt software installed on the Navman PiN will hog the port and not allow other software to access the port. I found it easier to delete SmartSt than to fool around with the NavMan settings, but it is possible to leave SmartST installed and turn off the GPS using a procedure that I no longer have.
David
106090
Reply By: Redback - Monday, Apr 11, 2005 at 09:06
Yes we do it and have SmartSt on, you just have to turn smartst off before going into oziexplorer and visa versa, works very
well with us only problem we have is getting maps that aren't 100 years old, some maps are that old you have to use WGS66.
Baz.
106108
Follow Up By: Never ending journey - Tuesday, May 10, 2005 at 19:04
Baz, does the pin have any trouble recovering the port once Oziexplorer is finished with it? I tried to run both on
mine and it would not let the Smart ST software have the port back.
Dean
367126
Reply By: GUPatrol - Monday, Apr 11, 2005 at 10:57
Guys,
I have the Navman PIN using SMartST (latest version), Oziexplorer CE with australia wide map from NATMAP all running at once with a 1gig card.
To run it all at once you just need GPS
Gate (Franson), it creates virtual com ports so you can run many things at once.
I also run other freeware available from the net to show speed satellites and other diagnosis stuff, whcih convert the device into a real GPS with all the functions a GPS has.
One of the problems with it is that there is no way to reset the GPS, the GPS does not reset when you reset the device.
There are however many utilities from Navman etc to send a reset command to the GPS should you ever need to, then it does a cold start.
If you have one of the older models, there are firmware updates available too...
Excellent little package
Will
106119
Follow Up By: REX.....(Adelaide) - Monday, Apr 11, 2005 at 17:30
CAN U HOOK A USB DEVICE SAY A LAPTOP HDD TO THE NAVMAN ?????
INSTED OF USING THE MMC CARDS
363218
Follow Up By: Redback - Monday, Apr 11, 2005 at 19:58
YES
363246
Follow Up By: Redback - Monday, Apr 11, 2005 at 20:11
And no you hook the laptop the navman via a USB cable but not a hard drive.
363249
Reply By: REX.....(Adelaide) - Monday, Apr 11, 2005 at 11:47
thanks for all the replys im going to but one a lot better than the lap top on the dash
106124
