Waeco vs Engel
Submitted: Monday, Apr 11, 2005 at 22:24
ThreadID: 21979 Views:33502 Replies:19 FollowUps:11
Hi all,
We were looking at fridge/freezers (for the road) on the weekend and noticed that there this a big difference in the current draw between the two brands. Comparing a 40L fridge/freezer - Engel 0.5-2.5 Amps / Waeco 0.5-6.0 Amps, with similar differences through the range. All other specs were about even. Can anybody enlighten me why the big difference and any comments on related experience?
Thanks in advance..Keith
Reply By: Truckster (Vic) - Monday, Apr 11, 2005 at 22:27
Serious dude, it has been asked a thousand times, try a search.
AnswerID: 106250
Follow Up By: Member Eric - Tuesday, Apr 12, 2005 at 23:28
Probably a newby Bruce , why not tell him that he can do a search , rather then bite his head off . Gee you can be mean
FollowupID: 363483
Reply By: CUM800 - Monday, Apr 11, 2005 at 22:27
Ohn no. I'm keeping my head down and right out of this.
AnswerID: 106251
Reply By: Rosco - Bris. - Monday, Apr 11, 2005 at 22:30
You sure you're not related to a fella goes by the name of Johnno1 or something similar ....... ;-))
AnswerID: 106252
Reply By: Member - Davoe (WA) - Monday, Apr 11, 2005 at 22:44
have a look at what all hard core exploration cos use not just those that go for the occasional picnic but those that depend on them- there is only 1 ENGAL
AnswerID: 106258
Follow Up By: PerthGQ - Monday, Apr 11, 2005 at 22:50
Thanks Davoe
FollowupID: 363278
Follow Up By: me and my dog - Tuesday, Apr 12, 2005 at 10:53
FollowupID: 363335
Follow Up By: Leroy - Tuesday, Apr 12, 2005 at 15:43
I have 1 ENGEL!
Leroy
FollowupID: 363385
Reply By: PerthGQ - Monday, Apr 11, 2005 at 22:48
Sorry fellas if I didn't make it clear enough, I wasn't looking for any comical responses nor trying to re-hash old posts, but asking if anybody knows WHY there's such a difference in the current draws. I've done the search and found many questions related to "which one shall I buy" or "which one will last longer on battery" etc, none of which answer what I'm after...Keith
AnswerID: 106259
Follow Up By: muzzgit (WA) - Tuesday, Apr 12, 2005 at 00:30
Although I hav'nt seen a comparison between the two in regards to how long they will last on a battery, logic would tell me that the engel with it's lower power draw should last longer.
FollowupID: 363297
Follow Up By: GaryInOz (Vic) - Tuesday, Apr 12, 2005 at 21:27
Why does a Ford V8 use so much fuel compared to a Daihatsu Sirion????
The two fridges use different methods of compressing the refrigerant, and therefore have their own specific current requirements. They also have different amounts of thermal insulation and different exterior materials that will affect the way the perform.
In short they are chalk and cheese, both do the same thing in different ways.
The Engel uses a linear compressor (bit like a bicylce pump connected to a solenoid) wheras the Waeco uses a conventional rotary compressor.
FollowupID: 363445
Reply By: Member - Stan (VIC) - Monday, Apr 11, 2005 at 23:09
They use different motors... The 40L Engel will set you back around $1200.
You can get 40L Waeco for around $650-750.... I don't really care for the max
power draw with such difference in the price. It is cheaper to get a more powerfull deep circle battery...
Will give a new 40L Waeco a run in July in the Simpson Desert.
AnswerID: 106263
Follow Up By: Redback - Tuesday, Apr 12, 2005 at 08:02
Yep my reason for a Waeco too, Engal is way over priced IMHO.
Baz.
FollowupID: 363311
Reply By: muzzgit (WA) - Monday, Apr 11, 2005 at 23:22
"They use different motors... The 40L Engel will set you back around $1200.
You can get 40L Waeco for around $650-750"....
but why not get the waeco 50L for less than a grand !!
AnswerID: 106266
Reply By: paulpp - Monday, Apr 11, 2005 at 23:25
Greetings Keith
The Engel uses its own design swing motor. The Waeco uses a Danfross motor. Hence the difference in current draw.
The Engel swing motor does not appear to interfere with HF radio systems. The danfross compessors/motors can.
My engel has survived the Kimberley's and Cape York without any problems ( held down with straps and no spring base). It is now 10 years old and going strong.
I have no experience with Waeco fridges.
http://www waeco .com.au
http://www.engelaustralia.com.au/
Paul P
AnswerID: 106267
Reply By: brian - Tuesday, Apr 12, 2005 at 07:21
Another point worth considering is the warrenty /support offered eg are you satisfied with a 12 month warrenty on a $1000 fridge ?? there is another brand with a danfoss motor with a 5 year warrenty,also some companies use secondhand parts to do warrenty repairs and then offer no warrenty on repaired unit.When i took mine in for repairs the workshop was covered in various fridges awaiting repairs,i have seen this in three workshops now which leads me to believe that there is a huge number of repairs to these fridges,
I am not bagging any particular fridge just trying to prompt people to investigate more thouroughly before you buy,I dont think my next fridge will be one with a twelve month warrenty.
AnswerID: 106294
Follow Up By: 80scruiser - Tuesday, Apr 12, 2005 at 08:08
Agree
I have an engel now and my next one will be an Evakool.
FollowupID: 363313
Follow Up By: Member - Stan (VIC) - Tuesday, Apr 12, 2005 at 10:03
The current Waeco fridges come with 3 Year Motor and 5 Year
everything else warranty. If both fridges were at about the same price
I would probably go for the Engel because of known reliability.
FollowupID: 363329
Reply By: Member - aussichef (SA) - Tuesday, Apr 12, 2005 at 09:13
I my self have a waeco 80 as i wanted seperate fridge & freezer if needed
But for under 1000 dollars look @ the Reefer brand a friend has one
his is 60 litres paid 800 for it new from the factory here in south oz
if id wanted a single compartment fridge thats the one i would have gone for
also look @ the waeco fridge shop online they always have specials
ask jimbo & brew69 they both bought good deals from there And i also think the engle is way over priced but my opinion only
warren
AnswerID: 106311
Reply By: Outbacktourer - Tuesday, Apr 12, 2005 at 09:13
Since we are on fridges, at Rosehill a mate bought one of the new "Downunder" fridge/freezers, a 50L. Like an EvaKool (esky type) but with an ABS exterior. The main interior comaprtment is SS and there are no elements exposed anywhere. Danfoss compressor and 5yr warranty. Transit bag, AC adapter etc for $1099. It's made by the Downunder Icebox people. New to the market it seems.
Funny, over at the EvaKool stand they had a fax on the wall with an enquiry from Rex Hunt asking where he could get a "Downunder" fridge he had just experienced on a recent trip because he was so impressed with it. Hmmm.
AnswerID: 106312
Follow Up By: Sand Man (SA) - Tuesday, Apr 12, 2005 at 09:37
At a 4WD show last year in Adelaide, there was a stand selling Downunder coolers.
Their marketing ploy was that the bloke running the company used to own, or work for, EvaKool... and that their "new" design started where the EvaKool left off. Yea Right!
Any company that uses this sort of tactic to flog their range, gets a wide birth from me, regardless of whether their product is comparable or not.
Bill
FollowupID: 363324
Reply By: Sand Man (SA) - Tuesday, Apr 12, 2005 at 09:29
Gee, my decision was much easier.
Went to a Camping Store 2-3 years ago and they had two brands, Waeco and Engel in the 40 litre size I was looking at.
The Waeco was $840. Plastic body. Looked OK. Separate transformer required to run it on 240v. (included in price)
The Engel was $870. Metal Body. Included a digital thermometer and transit base.
Decided there was value in the extra $30 outlay.
I'm still grinning:-)))
Bill
AnswerID: 106320
Reply By: Toy_Hilux - Tuesday, Apr 12, 2005 at 10:42
I don't know about anyone else but I one of each, my engel is about 8yr and the waeco is 3yr. I'm not saying that 1 is better than the other, they are both very a good fridge/freezer. Each has their pros and cons. One thing that I noticed is that the waeco has a high as well as a low amp draw (depends on which setting you want to use), also it has a built in cut-out so that when the battery level drops to a set level the fridge will cut out (can still start my car, [I use the High setting]). Handy if you only have one battery in vehicle. My engel doesn't, but you can purchase an optional cut-out switch for them (so the rep tells me).
Thats my 2 bobs worth
AnswerID: 106323
Reply By: me and my dog - Tuesday, Apr 12, 2005 at 10:52
Keith
have a look at this thread, as it talks about the factory setting for Australia for the Danfross and how it can be changed
http://www.exploroz.com/Forum/Archive/2005_1/20656.asp
Other then that, I use both and really havnt a preference
AnswerID: 106326
Reply By: andy - Tuesday, Apr 12, 2005 at 17:20
Not a direct answer to your question, but....
I was working in a remote NP in Qld in 1995 and bought an Auto Fridge. It was expensive $1200 at the time. It used to keep icecream frozen in summer after 5 hours sitting in the sun in the back of a ute returning from a ration run.
I was in the park in 2004 and the fridge is still going with zero problems. This is a government owned fridge and looked like a couple of roadtrains had run over it, it was constantly used. During longer camps it only had to be run a couple of hours a day to keep everything ice cold.
If you are looking at serious dollars then this is a very good option.(In my opinion)
AnswerID: 106380
Reply By: Member - Jimbo (VIC) - Tuesday, Apr 12, 2005 at 21:45
I didn't want to get into this again, but here goes.
I've owned both.
I went from an Engel 39L that had served me very well for six years to a Waeco 80L because I needed a bigger fridge (perhaps my liver didn't but that's another story).
Here's the verdict......
wait for it,
they both keep things cold.
Buy a fridge according to the layout/design/budget etc that suits you.
Of all the reputable brands, and there are many, I don't believe there is a dud out there.
Jim.
AnswerID: 106441
Reply By: Willem - Tuesday, Apr 12, 2005 at 22:18
As long as it keeps things cold...who cares?
Saying that...I have 2 Engels. One is a 1985 model and still going strong(never even been serviced) and the other is a 2002 model. No problems from either.
Horses for courses I guess
AnswerID: 106451
Follow Up By: Member - Jimbo (VIC) - Tuesday, Apr 12, 2005 at 22:32
Wise words Willie.
"Who cares"
I don't. My Philips fridge at home has been working well for 23 years, and Philips don't even make fridges these days.
It's just a fridge.
FollowupID: 363465
Reply By: TheUndertaker - Wednesday, Apr 13, 2005 at 07:35
Have 3 fridges/freezers , 1x40lt chescold draws 10amps constant , 1x15lt engle draws 3.3amps per hr average over 24hr , 1x80lt waeco draws 3.5 amps per hr over 24 hr average ,,,,
now to answer your question ,
chescold lots of amps ,best on gas, long camps,infrequent opening,
baby engle ,used as drinks[beer] frequent opening + restocking = amps
mega waeco, icecream wherever you go, BIG fridge + freezer = amps
as Jimbo and Willem put it, "only a fridge" ,,the only thing that matters is that you have the $ to supply the power / batt / gen / solar / gas / to keep the overpriced toys running and the beer cold.
AnswerID: 106475
Reply By: PerthGQ - Friday, Apr 15, 2005 at 21:03
To all, Thanks very much for the constructive info. Much appreciated on the design differences between the two brands and feedback on experiences.
Cheers..Keith
AnswerID: 106957
