100 series LC timimg belt light
Submitted: Wednesday, Apr 20, 2005 at 20:44
ThreadID: 22238 Views:1664 Replies:4 FollowUps:1
Apparently the timimg belt in my new LC has been replaced but the mechanic was not aware how to reset the warning light. I've had a look at the appropriate threads here but from what I could see the 100 series doesn't have clearly labelled timing light screws.
Anyone have any personal experience with this?
Reply By: Member- Marc - Wednesday, Apr 20, 2005 at 21:36
G,
Is there another pin you would push in the dash, like the pin you push to reset an anolog speedo?
It may have a little rubber cover over it.
Hope this helps.
Marc.
AnswerID: 107599
Reply By: 80scruiser - Wednesday, Apr 20, 2005 at 21:58
I have posted how to do it a while ago.
I will try and find the thread.
You do it through the odometer setting.
I presume yours has done 150 k now.
I'll get back to you shortly.
AnswerID: 107602
Follow Up By: 80scruiser - Wednesday, Apr 20, 2005 at 22:07
I had trouble finding my post but try this
It is the same.
FollowupID: 364496
Reply By: G-wizz - Thursday, Apr 21, 2005 at 07:43
Thanks, I will give that a try.
AnswerID: 107636
Reply By: KiwiAngler - Thursday, Apr 21, 2005 at 17:18
http://f4.grp.yahoofs.com/v1/cE9nQmwt1Wapnb9rQizYUoGr4SyY-7c68lkFs7-SIKObTdah0cD5unEU6ARxBsoF1wKf81rmad18ZiE1G3LrheAJS73GU3Y7auP1bg/100timing%20belt%20reset.JPG
cut and paste into yr browser. Takes a while to load up.
AnswerID: 107696
