Freeing up low range
Submitted: Friday, Apr 22, 2005 at 22:55
ThreadID: 22303 Views:1844 Replies:5 FollowUps:2
Any body got tips on freeing up the low range selection in a 79 series? it is an unavoidable problem on minesite vehicles and is becoming a hassel in our work ute especially iff you dont have an offsider to kick the lever accross
Reply By: John - Friday, Apr 22, 2005 at 23:28
1st attempt - Lots of WD40 sprayed at linkage from underneath vehicle.
2nd attempt - remove cabin transfer gear boot and spray with lots of WD40!!
Worked for me in 2003 and have been through lots of dust and water since without return of problem.
AnswerID: 107907
Reply By: V8Diesel - Saturday, Apr 23, 2005 at 10:11
Yeah, I find mine is especially hard to get in at around the 110km/h mark....;-)
But seriously...They've got bugger all leverage / mechanical advantage. I was toying with making up an extension for the lever on my 75. When I was doing exploration, we'd drive them 'Mack twin-stick' style, shifting on the fly with the left hand changing gears, right arm through steering wheel and swapping from Low 5th to High 3rd on the go.
If the 79's always on-site in 4WD, a bit of transmission 'windup' may be your problem going from H to L. Try reversing backwards for a bit to see if it's an external (seized, mud) or internal(windup/fault) issue. Better still, go 2wd, stop, select 4H then 4L.
A thought I had just this week, after playing in lots of mud on the weekend, was to simply cable tie a couple of lengths of garden hose from the edge of the tray to the transmission tunnel area for a quick 'de-mud' spray when I get home. Just click on the hose and have a beer until the water is coming out clean. The bash plates on mine mean the only other way I can get to clean this area is to lie in muddy water under the vehcicle and get covered in crud. Very boring.
This would cost under $10 to make and keep the linkages, shafts clean(er).
AnswerID: 107931
Reply By: Exploder - Saturday, Apr 23, 2005 at 12:14
Yep they r a mongrel to get in gear when there not used much.
Try a hydraulic ram and if that doesn’t work then swear and call it names. It won’t make it work but you will feel better. :)
See if you had electronic 4WD selection you wouldn’t be having this sort of problem.
Instead light’s would be flashing at you and it would be making buzzing and clicking sound’s:)
AnswerID: 107939
Follow Up By: Member - Davoe (WA) - Saturday, Apr 23, 2005 at 14:09
Gets used at least 4 times a day in and out. After the post I did the obvios and gave it a good hose out and crc - worked a treat but I suspect it will need regular crc ing from now on. If left unattendd it can actually become immpossible to select l range or h range (depending)
FollowupID: 364791
Reply By: TonyH - Saturday, Apr 23, 2005 at 12:47
Usually it is the detent ball with a bit of water..... goes to crap. not hard to whip them out and give them a clean. Never done one with oil in the case though can't say if they would leak oil, I would imagine they do.
I'll go and have a squizz and let you know
Tony Harding
West Arrino WA
AnswerID: 107941
Reply By: Coops (Kalgoorlie) - Saturday, Apr 23, 2005 at 20:26
Davoe
this happened to my wheels too. After pulling everything apart and thinking we fixed it I also sought advice form this forum.
CRC did the trick and I give it a regular dose every month or so now.
Coops
AnswerID: 107961
Follow Up By: Coops (Kalgoorlie) - Saturday, Apr 23, 2005 at 20:28
so as not to mislead you - by wheels I meant my cruiser
FollowupID: 364810
