Pajero LPG conversion
Submitted: Saturday, Apr 30, 2005 at 20:56
ThreadID: 22526 Views:3812 Replies:1 FollowUps:1
Help please,
We have an NP 2003 Pajero and would like to know if anyone has converted this model to LPG. If so, are there any particular problems to be aware of and what were the results - costing, performance, size and position of tank etc. Any recommendations for who to see in the outer western area of Sydney?
Thanks, Alva.
Reply By: muzzgit (WA) - Sunday, May 01, 2005 at 01:39
From what I remember, you fuel tank is underneath at the back, which is where an LPG tank would go. This means putting smaller belly tank in. Can be costly.
Unless you put the LPG tank in the rear cargo area, which will take up a lot of space.
AnswerID: 109029
Follow Up By: gqpat - Sunday, May 01, 2005 at 19:12
As a LPG fitter be very wary when fitting gas to your Pajero as they have a big habbit of backfiring on gas alot , if you go ahead fit proper LPG leads should be spiral wound wire core NOT CARBON and fit non resistive plugs dont worry about whats in it for petrol hopefully you might be OK Goodluck
FollowupID: 365809
