80 Series Timing Belt Lamp
Submitted: Sunday, May 01, 2005 at 23:30
Simon M
Hi All
I've got a 90 model 80 Series 4.2 Diesel - Base model, with the timing belt light on. Does anyone have the reset procedure for these vehicles?
Thanks in advance.
Simon
Reply By: Footloose - Monday, May 02, 2005 at 08:29
Simon, why is the light on ? They are set to come on every 100K when the timing belt needs replacing. If you haven't already, get it replaced. If you don't, you could be up for a new engine.
To turn the light off, in the plastic cover to the dashboard instruments cluster there's a small rubber grommet about half way across. Prise it off, insert a small screwdriver or whatever and push gently.
109167
Reply By: age - Monday, May 02, 2005 at 08:41
I agree, get the belt changed now !!. This motor is an "interference" motor where valves etc will touch pistons if the timing belt goes - big $$"s to fix. I know of two recent cases where the belt was left 12000km past due date and let go.
109171
Reply By: Simon M - Monday, May 02, 2005 at 10:39
Thanks for that. Don't worry I've had the belt changed but could never reset the light. I have tried the procedure you mention but without success. Is there a technique to it - Meaning do I need to maintain pressure on the panel for a period of time etc?
Thanks again
109191
Follow Up By: Member- Rox (WA) - Monday, May 02, 2005 at 10:55
every time you push it it comes on or off so keep trying
365890
Follow Up By: Footloose - Monday, May 02, 2005 at 14:11
I just push
mine in and it goes off.
365923
Reply By: Member - DOZER- Monday, May 02, 2005 at 15:48
If pushing the button doesnt turn off the light, remove the bulb...that will fix it...
Then make note of the kms for next time...
109234
Follow Up By: udm - Monday, May 02, 2005 at 21:49
Has anybody seen Mr QuickFix?
365964
