Site Search
Section Image
Storing a battery not in use
Submitted: Monday, May 02, 2005 at 19:33
Brew69(SA)
Any suggestions as to the best way to store a battery not being used? How long until they die idle?
Beer is evil.........And i am an evil man.
Advertisement
ThreadID: 22580 Replies: 11
Views: 1302 FollowUps: 17
AnswerID: 109280   Submitted: Monday, May 02, 2005 at 19:45
Exploder replied:
Gday Brew69
You can by a solar powered charge holder from auto shops, or just put it on a charger every month.
Reply 1 of 11
AnswerID: 109284   Submitted: Monday, May 02, 2005 at 19:52
Member - Roachie (SA) replied:
G'day Brew,
Just my opinion, but if it's a 'normal' lead-acid battery, I would suggest you don't store it on concrete (place it on a piece of timber etc) and preferrably keep something attached to it light a cheap flouro light etc. Also attach a DSE cheap voltmeter and keep your battery charger handy, giving a trickle charge every now and then. As an alternative to the voltmeter, get a multimeter (lots of other uses too) and periodically check the status of the battery. I believe you would also need to use a hydrometer periodically too.
However, if its a sealed battery (I have one on my work bench from the bank which was for the alarm back up system), they are capable of holding an excellent state of charge for several years. I've had this one on my bench for over 5 years and just use it to power a small drill/power tool (similar to a Dremel) and my old ARB compressor when the kids bike tyres need pumping up. An occasional hit with the battery charger every 6 months or so for about 24 hours and she's back up to peak level. I don't think it's be built well-enough inside to be able to cope with the rigors of corrogations etc.
Just my opinion....there are heaps of better informed blokes around than me.
Cya mate
Roachie
Click Image to Enlarge
There's only one thing more painful than learning from experience and that is NOT learning from experience!
Reply 2 of 11
FollowupID: 365950   Submitted: Monday, May 02, 2005 at 20:08
Footloose posted:
Roachie, why not a concrete floor? How does that do anything ? I've been dying to ask that :))
FollowUp 1 of 6
FollowupID: 365955   Submitted: Monday, May 02, 2005 at 20:48
TheUndertaker posted:
Roachie ,what a load of dribble,,the MYTH of storing a batt on concrete being bad for the batt stems from when battery cases were made of timber and tar which invariably leaked acid. check www.uuhome.de/williamdarden/carfaq
FollowUp 2 of 6
FollowupID: 365995   Submitted: Monday, May 02, 2005 at 23:24
Member - Roachie (SA) posted:
Happy to be corrected Undertaker....... I did say that there were heaps of blokes who were better informed than me.....and it looks like you're one of them.
Thankyou for setting me straight....I won't bother making sure I always keep my stored batteries off the concrete any longer.
Cheers mate
Roachie
FollowUp 3 of 6
FollowupID: 366014   Submitted: Tuesday, May 03, 2005 at 08:43
Sand Man (SA) posted:
I'm going to be much more subtle than them other buggers Bill.
He's what I found:-
"Storing batteries under 250 AH on concrete floors will not cause them to naturally self discharge faster."
So you are in fact partially correct in your knowledge mate.
HooRoo !
FollowUp 4 of 6
FollowupID: 366016   Submitted: Tuesday, May 03, 2005 at 08:49
He's what I found:-
Apart from that, a trickle charge is recommended to stop sulfation of battery plates. This can be via "float" charge from a 3 stage charger, or a small solar panel of at least 5 watts. (for car batteries)
HooRoo !
FollowUp 5 of 6
FollowupID: 366017   Submitted: Tuesday, May 03, 2005 at 08:56
Footloose posted:
I knew that I was opening a can of worms, that's why I added the :))) with my question.
From my training days, temperature does of course affect batteries and their effeciency. All we old timers think that it's "common wisdom" that a battery on concrete will shorten battery life, although I've never seen any emperical evidence to prove this.
I wonder if the "evidence" actually comes from Europe and the States where the temperature differences are more severe in winter ?
I've left working batteries on concrete and wood with no observed difference in performance or oseable life. But I haven't measured them in any way in an effort to prove or disprove the advice.
FollowUp 6 of 6
AnswerID: 109292   Submitted: Monday, May 02, 2005 at 20:25
Peter 2 replied:
a concrete floor will discharge the battery, buggered if I know why but it does, I've tried it several times over the years.
sitting the battery on a piece of steel will discharge it too, that's why there is a plastic tray under the battery in the car apart from catching acid overflows, if you put a battery in a steel battery carrier without a piece of ply or rubber under the battery it will slowly discharge.
Madigan Line 07
1988 M1026 Humvee
Reply 3 of 11
FollowupID: 365952   Submitted: Monday, May 02, 2005 at 20:34
Diamond (Vic) posted:
thats just an urban myth.
leaving it on concrete or leaving it on steel dosnt matter if you dont use it it will bugga up.
FollowUp 1 of 4
FollowupID: 365956   Submitted: Monday, May 02, 2005 at 20:57
Peter 2 posted:
Actually it isn't, try it yourself, over a period of time the battery will flatten noticeably quicker if sitting straight on a concrete or steel surface rather than a bit of timber, I know I've tried it, same battery charged to the same SG and regular measurements at preset intervals, it DOES make a difference.
Madigan Line 07
1988 M1026 Humvee
FollowUp 2 of 4
FollowupID: 365957   Submitted: Monday, May 02, 2005 at 21:19
Funny that every battery shop stores its batts on oh no ,STEEL shelves ,every Kmart tyre and mechanical w/shop stores its exide batts on an exide supplied oh no steel shelving/display unit ,,, old , very old myth lol.
FollowUp 3 of 4
FollowupID: 366121   Submitted: Tuesday, May 03, 2005 at 21:06
Member - Jimbo (VIC) posted:
Urban myth,
See the post and link below from Brian.
FollowUp 4 of 4
AnswerID: 109299   Submitted: Monday, May 02, 2005 at 20:59
TheUndertaker replied:
A normal 12v wet cell batt self discharges at 10/15% per mth ,,battery world /supa cheap/dick smith/tandy/ jaycar /ect all sell a small battery maintenance charger called "Battery Fighter Junior" ,costs round $40 ,,takes batt to 14.2v then trickle charge to keep at 13.2v in maintenance mode indefinitly ,,, also checkout
www.uuhome.de/williamdarden/carfaq.
Reply 4 of 11
Activities Index
Uluru Motorcycle Cruise Uluru Motorcycle Cruise
Alice Springs and Central Australia - NT
Enjoy the awesome thrill of seeing one of Australia's best known landmarks Ayers Rock as a passenger
V8 SUPER DRIVE - NSW V8 SUPER DRIVE - NSW
Sydney - NSW
Experience V8 Racing / Driving at its best, with the best, you and a professional race car driver be
Poker Tournament Poker Tournament
Melbourne - VIC
For an event with style and excitement, why not host your own poker party or poker tournament.
3 Hour Natural Spa Treatment 3 Hour Natural Spa Treatment
Sydney - NSW
Come and let us pamper you with our 3-step Jobonga natural spa treatment, which includes feet treat
Book Now - Things To Do
AnswerID: 109314   Submitted: Monday, May 02, 2005 at 21:31
Lone Wolf replied:
Okay fella's, let's call the....MYTH BUSTERS!!!!
"Okay Jamie, today we're going to discharge a battery."
"Um, Adam, like through a cannon?"
"Duh, no Jamie, were going to do it the Aussie way...... with concrete!"
"What' like drop a concrete slab on it?"
"That sounds like a plan.........."Wolfie
Reply 5 of 11
AnswerID: 109324   Submitted: Monday, May 02, 2005 at 22:01
Member - Jimbo (VIC) replied:
I'll try and explain this as best I can.
The theory of batteries losing voltage on concrete goes back about a hundred years. It was when batteries were lead and acid inside a wooden box sealed with pitch (tar). If the pitch leaked the acid made contact with the concrete and the charge was thus siphoned out out into the concrete.
It simply doesn't happen anymore. Batteries are now sealed at the bottom of them and do not lose charge this way.
As Jim (diamond) said, it is urban myth.
Jim.
Reply 6 of 11
FollowupID: 365987   Submitted: Monday, May 02, 2005 at 22:40
Exploder posted:
Gday all
I think the battery loosing charge when sitting on concrete could be caused by the concrete getting colder over night than say a piece of wood and thus affecting the battery that way.
Does this sound plausible
Any electrical engineers out there!
Wouldn’t worry me anyway if it goes flat charge it. Why r we storing battery’s on shed floors anyway just a place for them to be damaged.
FollowUp 1 of 3
FollowupID: 366118   Submitted: Tuesday, May 03, 2005 at 20:56
Fair call exploder,
Batteries will hold lower voltage when cold, however do not lose charge(other than normal loss whilst standing). A batt when cold will show a given voltage which will increase when it gets warm without adding any charge.
As for why worry if it goes flat? Flattening a battery seriously shortens its life. Keeping them fully charged is the best way to prolong their life.
Jim.
FollowUp 2 of 3
FollowupID: 366316   Submitted: Thursday, May 05, 2005 at 01:23
Mainey (WA) posted:
Jimbo has said it correctly, concrete or cotton wool, it does not matter what the battery sits on.....
(Quote)The theory of batteries losing voltage on concrete goes back about a hundred years. It was when batteries were lead and acid inside a wooden box sealed with pitch (tar). If the pitch leaked the acid made contact with the concrete and the charge was thus siphoned out into the concrete.
As Jim (diamond) said, it is urban myth. (end quote)
Charge the battery and leave it on a regulated battery charger permanently, if you believe the concrete myth, then you can place it on timber or an old lounge chair, just for added comfort.
FollowUp 3 of 3
AnswerID: 109329   Submitted: Monday, May 02, 2005 at 22:21
Member - Duncs replied:
Brew,
I had a neighbour a few years back who was heavily into touring wiht his 4wd and camper trailer. Once a year he would hook up and head off for a couple of months.
On his return his routine was amazing. One day I cought him polishing his car. He had stripped everything ou of it seats carpet etc and was polishing the floor in the drivers footwell. It would have been a great car to pick up when he was upgrading.
What he did with his battery from his camper which was about 1000 years old was drain the acid and only refill it about a week berfore he set off on the next trip. HTen he would put it in the trailer and hook the charger to it for long slow charge.
My camper battery gets a little solar charger and has been going for about two years now and looks good for a bit more.
Duncs
Eric the Emu at home
Content with where I am but looking for somwhere else to go. Pic 1 Eric the Emu at home Pic 2 camped on Cooper Cr
Reply 7 of 11
FollowupID: 366141   Submitted: Tuesday, May 03, 2005 at 21:58
Member - Ross H (QLD) posted:
duncs
you are right on the money that is how i was shown to long store a battery.
remember motor bike batteries are dry when you buy them and you have to fill them with the bottle supplied
regards ross
Baby Bandag
FollowUp 1 of 2
FollowupID: 366322   Submitted: Thursday, May 05, 2005 at 07:13
Big Woody posted:
Duncs,
This method is correct but you have to make sure that you fully charge the battery before you drain it.
The reason for this is that the plates absorb the particles in the electrolyte as a battery is used. If you drain it when discharged and then later add new acid, you end up with not much capacity left in the plates to absorb any of the new electrolyte and you battery will have a very small range between fully charged and fully discharged.
I hope this makes sense.
Brett
FollowUp 2 of 2
AnswerID: 109332   Submitted: Monday, May 02, 2005 at 22:37
Big Woody replied:
Hi All,
I worked in a battery shop for 5 years and I think you will find that storing a battery directly on concrete (or thick steel) will shorten it's usable life purely from the fact that the concrete is cold.
Batteries in Cairns last longer than batteries in Tasmania.
Temerature plays a big part in the life of a battery and storing it in a place where it is in contact with constant cold temperatures can destroy a new battery in 6 months.
Most battery shops will have the batteries stored on conveyor belt rubber for this reason.
I have 4 batteries stored in my shed - A spare Supercharge calcium for the 4WD, A Delkor Marine for the Yacht, and 2 Delkor deep cycles for the yacht. These are all stored on a shelf with insulation rubber under them.
Brett
Reply 8 of 11
FollowupID: 366120   Submitted: Tuesday, May 03, 2005 at 21:04
Brett,
i lived in Townsville for 8 years. Heat certainly does influence battery life. A batt that is under a car bonnet in hot conditions will die very quickly as it it always too hot.
I had more battery failures in Townsville (under car bonnets) than I have ever had in Melbourne.
Jim.
AnswerID: 109343   Submitted: Monday, May 02, 2005 at 23:02
Bilbo replied:
Hmmmm, ya learn something every day!!
Bilbo
Reply 9 of 11
AnswerID: 109375   Submitted: Tuesday, May 03, 2005 at 07:16
Member - Brian (Gold Coast) replied:
This page answers the questions about concrete floors and colder weather
My Chrissy Prezzy
http://www.goldcoast4wdclub.org.au/
Reply 10 of 11
FollowupID: 366119   Submitted: Tuesday, May 03, 2005 at 20:59
Brian,
That pretty much sums it up.
Jim.
AnswerID: 109485   Submitted: Tuesday, May 03, 2005 at 17:51
Max - Sydney replied:
Hey Brew - sorry to offer concrete information when you've had so much expertise offered, but I bought a little battery charger from Bunnings for $50 or so. I hook up the caravan battery to it when we have to be off the road for more than a month, and it gives it a trickle when it drops below about 13v or so.
Great excitement going into the shed and seeing the red light come on about once a month to charge it up. That makes me think that a month is about the longest you should go without doing something. Might put it on the concrete floor to see if it has to chrge more often. LOL
Max
Reply 11 of 11
