Site Search
Section Image
Rear wheel carrier
Submitted: Monday, May 02, 2005 at 20:35
GraemeW
Hi Has anyone made their own rear wheel carrier?
I need one for a hilux and no company ( so im told in Perth ) makes one.I already have a good heavy duty rear bar with reece tow hitch.Any hints would be appreciated
Graeme
Advertisement
ThreadID: 22585 Replies: 6
Views: 819 FollowUps: None
AnswerID: 109325   Submitted: Monday, May 02, 2005 at 22:10
Member - Duncs replied:
Graeme,
I built one years ago for an old short MQ, the one with the resin top. My car had extensive bar work including a bar runnig up the rear corners of the car and across the roof supporting the roof rack from the rear bumper. I swung the wheel carrier off this on a pair of hinges. It was built from one inch square tubing that I had lying around at the time and was pretty much like the framework for a gate. The spare was then mounted onto a spare wheel bracket I picked up at the local wreckers. Make sure the stud pattern matches yours beore taking it home. All this was held closed by an overcentre clamp from Universal Engineering at Marrickville.
Probably a better idea for you would be what a mate did.
He had a Landrover County which he had built a rear step for. It was a nice bit of gear, very solid. He mounted a stub axle on this, I think it was bolted on. Weld the thread from a towball onto the fat end of the axle poke it through the bar and do it up tight. I think. I'm not sure if he manufactured a hub himself or used one from a trailer and swung his wheel carrier off that using standard wheel bearings for the pivot. Again a spare wheel bracket welded to the framework carried the spare. He fitted it up with a few really nice touches like a stopper to prevent it swinging closed when parked on a slope and a remote release so he did not have to bend down and reach under the wheel to release it.
Mine was a little light but not this thing he could use it as a ladder to climb onto the roof rack.
The best place to get ideas is at the local car park or next time you are in a caravan park, check out what is on the cars you see around and make notes or take photos.
It is very satisfying to build something yourself. Even better if other people like it and want to copy it.
Let us know how you get on.
Duncs
Eric the Emu at home
Click Image to Enlarge
Content with where I am but looking for somwhere else to go. Pic 1 Eric the Emu at home Pic 2 camped on Cooper Cr
Reply 1 of 6
AnswerID: 109356   Submitted: Monday, May 02, 2005 at 23:45
Member - Royce replied:
I built a twin setup on the SupaTrupa. I guess what I did with scrap, may not suit you or even apply to your vehicle. I had great fun building it. I can weld well enough for stuff to stay together, but it takes a fair bit of grinding to make it presentable [sort of]. I think the crucial thing is to consider stresses. Where will it fatigue and how can you support the wheel when it is locked in place. I used bearing hinges from Bunnings used in garden gates. I've bounced over a lot of corrugations since and to my amazement [touch wood etc] it's still holding together.
Mt Wellington Tas.... a long ago van.
Royce
Reply 2 of 6
AnswerID: 109373   Submitted: Tuesday, May 03, 2005 at 07:13
db courier replied:
hi graeme i built one on the courier mounted to the existing rear bar/step.
Reply 3 of 6
AnswerID: 109376   Submitted: Tuesday, May 03, 2005 at 07:17
db courier replied:
hi graeme, i built one for the courier off the existing rear bar/step. just weld a piece of flat bar to the bar, weld stub axle to that and swing an rhs frame off the stub axle via some wheel bearings. i have seen a few made with just hinges or steel shaft/bronze bush but they seem to sag and are heavy to move.
Reply 4 of 6
Activities Index
Two Car Rally Blast - VIC Two Car Rally Blast - VIC
Melbourne - VIC
Are you ready for a real rush?
Vineyard Meander Horse-drawn Wagon Trail Vineyard Meander Horse-drawn Wagon Trail
Perth - WA
Located in Henley Brook only 25 mins from the Perth CBD, the award-winning wagon trails provide a le
2hr Spyder Roadster Thrill Ride 2hr Spyder Roadster Thrill Ride
Gold Coast - QLD
What better way to get the adrenaline pumping than on the back of a 1000cc 106BHP powersport monster
Motorcycle Hire & Ride Day - VIC Motorcycle Hire & Ride Day - VIC
Melbourne - VIC
Hire a bike and ride all day, as fast as you like!
Book Now - Things To Do
AnswerID: 109413   Submitted: Tuesday, May 03, 2005 at 10:12
Drew - Karratha replied:
G'day Graeme
A few years back I built a twin carrier for my 80 Series. I went to a trailer parts shop and bought hubs that I welded into the new rear step, and welded the stub axles onto the arms that hold the spares. So far it has survived various trips around the Pilbara, the GRR a couple of times, Kakadu etc... I even stuch a couple of Opposite Lock stickers onto it and was later asked by an Opposite Lock employee if it was one of their earlier models....
Drew
Reply 5 of 6
AnswerID: 109499   Submitted: Tuesday, May 03, 2005 at 19:45
Member- Rox (WA) replied:
Have you tried K&N fabrications near the swan brewery? Bannister Rd
This land is cursed; the animals hop not run, birds run, not fly and the swans are black not white
Dirk Hartog, 1688.
Reply 6 of 6
