AnswerID: 109382 Submitted: Tuesday, May 03, 2005 at 07:38
gqpat
replied:
If it is a GQ just did mine recently 1 radiator shroud or better still radiator 2 there are 3 6mm threads in front pulley attach a pully remover remove 10mm head nut in middle first pull off front cover plate the pulley it self will remain on compressor then remove circlip from behind this plate ,then the pulley itself should come off by hand then just knock out bearing and refit
Was quoted anywhere from $48-78 for bearing so
shop around whole process should take 1-1.5 hrs and you dont need to remove compressor...
Reply 3 of 5
