To post yperlinks..How to do it?
Submitted: Saturday, May 07, 2005 at 08:27
Member - RockyOne
Anyone bring me up to speed on how to "legally" post pix or txt using the mentioned Hyperlinks which is all new to me....Is it described somewhere on this site..Examples? Please,just a lonely voice crying out in the wilderness of technology.
Reply By: Sand Man (SA) - Saturday, May 07, 2005 at 09:08
Yes,
Will Member Message you with a Word Doc.
110133
Reply By: Sand Man (SA) - Saturday, May 07, 2005 at 09:13
Second thoughts. Why don't I just put it in here & others may benifit.
Hyperlink Procedure:
At the bottom of a Post Follow-up or Post Reply you will see the following:-
To Post Hyperlinks:
For links: link text
Use Windows Copy & Paste to insert the hyperlink into your Post
Select the Hyperlink line, leaving out For Links: by holding down the left mouse key and swiping the remainder of the line so that it is highlighted. Press the Ctrl and C keys together to copy the selection into memory.
Place the cursor at the desired position in your Post and Press the Ctrl and V keys together to Paste a copy of the selected text into the Post.
The domain.com/path is replaced with your Website URL (in the case of the sample I have used the Exploroz Website) and optionally, the link text bit with something along the lines of:- Exploroz.
So, ignoring the For Links: prefix, you should end up with:-
Exploroz
The result on the
forum post will show simply as Exploroz and if you place the cursor over the link reference, the full URL will be displayed.
Bill
(Sand Man)
110134
Follow Up By: Sand Man (SA) - Saturday, May 07, 2005 at 09:15
Bugger, It converted when I didn't want it to. Now I know why I had the Word Document:-)
366713
Follow Up By: Pluto - Sunday, May 08, 2005 at 09:11
Sand Man's example should have looked like this (Now let's see if is works this time)
For links: <a href="
http://domain.com/path">link text</a>
366806
Reply By: Sand Man (SA) - Saturday, May 07, 2005 at 09:23
OK,
Have put a simple "how to" document in Members File Swap.
110136
Reply By: Troopy Travellers (NSW) - Saturday, May 07, 2005 at 09:30
!MPG:10!
Not sure if this is big enough to see. Carolyn
110137
Follow Up By: Troopy Travellers (NSW) - Saturday, May 07, 2005 at 09:32
If you click on it, it come up big enough to read and you can see what you copy and paste to link and give a name to the link if you want. Carolyn
366715
