Urgent help needed-rancho shockers which way up??
Submitted: Sunday, May 08, 2005 at 15:38
ThreadID: 22771 Views:2540 Replies:6 FollowUps:10
G'day
Just replacing my shockers for a gu patrol, bought rancho 5000's alround. They have a solid body with the telescopic shaft (covered by flexible cover) which part of the shockers go on top. Ie does the telescopic shaft go on top or bottom.
Help I'm racing the clock (and the sun)
Rod
Reply By: nick riviera - Sunday, May 08, 2005 at 15:40
the telescopic shaft up top
AnswerID: 110302
Reply By: Member - Jiarna (SA) - Sunday, May 08, 2005 at 15:41
Whichever way they fit in the wheelie bin hahahaha
AnswerID: 110303
Follow Up By: Member - Jiarna (SA) - Sunday, May 08, 2005 at 15:42
Sorry couldn't help myself!!
Yes the telescopic part goes upwards.
FollowupID: 366828
Follow Up By: Wayne (NSW) - Sunday, May 08, 2005 at 15:45
John,
That was not very nice, but very funny.
Should be in your part of the world in July.
Wayne
FollowupID: 366829
Reply By: dirtdodger - Sunday, May 08, 2005 at 15:42
The body of the shocker mounts to the axle,and the telescoping bit ( the shaft with the boot on it) mounts to the chassis....the top.
AnswerID: 110305
Reply By: woddonnee - Sunday, May 08, 2005 at 15:43
Thanks very much for the quick replies
Back to work
Rod
AnswerID: 110306
Reply By: Muddy 'doe (SA) - Sunday, May 08, 2005 at 16:10
Ahhhhhhh I love this site!
Another problem solved.........
Muddy
AnswerID: 110309
Reply By: fatz - Sunday, May 08, 2005 at 16:58
Only temporarily solved, he'll be pulling them out again in six months cause they'll be stuffed!!
AnswerID: 110312
Follow Up By: Truckster (Vic) - Sunday, May 08, 2005 at 17:46
6 mths? Your generous!!!
FollowupID: 366852
Follow Up By: RussellP - Sunday, May 08, 2005 at 17:53
I replaced mine after 3 months.
FollowupID: 366856
Follow Up By: Member - Andrew(WA) - Sunday, May 08, 2005 at 17:54
So what shocks would you recommend for a GU?
FollowupID: 366857
Follow Up By: udm - Sunday, May 08, 2005 at 17:56
Is that how good they are? 3 months?
FollowupID: 366858
Follow Up By: RussellP - Sunday, May 08, 2005 at 18:44
Don't know much about GU's.
Mine were Rancho 9000's (the adjustable ones) on an 03 Navara. Just couldn't get a right setting for them and they went off quickly when used on corrugated roads. Ended up putting the factory ones back on. Been good ever since.
Mind you, I kept the 9000's onthe rear, set them to 3 (softish) and put some load levelers on.
Russell
FollowupID: 366866
Follow Up By: Truckster (Vic) - Sunday, May 08, 2005 at 19:15
I went through 3 sets, threw them in the bin in the end.
my first set lasted about 3 mths, they were 9000's.. they didnt have them anymore, only 9x's.. They wanted to charge me the difference in $ between the 2.. Not my fault your stuff is not up to it...
Old Man Emu.
But try searching theres 100,000 threads on this subject
FollowupID: 366870
Follow Up By: Member - Jiarna (SA) - Sunday, May 08, 2005 at 20:35
100,001 threads now
FollowupID: 366882
Follow Up By: Rick (S.A.) - Monday, May 09, 2005 at 07:45
What do I recommend? Ridepro.
As Truckster says, do a search here.
FollowupID: 366914
