AnswerID: 8173 Submitted: Monday, Nov 04, 2002 at 00:00
OziExplorer
replied:
Solar panels are great. You need to have them in the sun, and during the day move them to the best orientation for the sun. In summer it is not to bad, because the sun is directly overhead, and placing them flat on the ground is acceptable. During winter, you will need to move them a minimum of three times during the day, to get optimal results.
Solar panels need to be correctly setup with the right type of battery and the load checked against what you want to run from them.
Personally, I prefer at least 100w plus, and 120w would be my minimum recomendation. However, if you just want to run a few lights and radio and keep your vehicle battery topped it, 60w would be fine.
These BPSX60 at $576 incl GST and freight are a good buy.
http://www.coiltek.com.au/Products/solar_panels.htm
BP solar are one of the top panels, and crystaline solar panels like the BP have a substantially longer life than Amorphous solar panels. Amorphous solar panels are better in partial shade conditions, but the wattage/amperage they supply over time does deteriorate and the longevity of the panel is not there compared to crystaline panels.
Reply 3 of 5
