Sand Flags
Submitted: Monday, May 09, 2005 at 07:31
ThreadID: 22794 Views:2244 Replies:10 FollowUps:1
Heading to the CSR any ideas where one can purchase a flexible sand flag/pole.
I used an old surf rod for the Simpson but it broke off before Dalhousie.
Mike
Reply By: Outnabout David (SA) - Monday, May 09, 2005 at 07:41
outbackideas@three.com.au
It is a great 3 piece flag that doesn't break, comes with mounting bracket and under $100
AnswerID: 110380
Reply By: Nick R - Monday, May 09, 2005 at 08:28
a fishing shop could sell you a "wog pole" actually a squid pole. Willem uses one apparently... Bought JohnR a 7 metre one but it broke unfortunately, maybe a 5 or 6 metre would be better, not too expensive either.
NickR
Carpe Cerevisi
AnswerID: 110388
Reply By: Tim (vic) - Monday, May 09, 2005 at 09:10
Go to Kmart or a cheap fishing shop you should be able to buy a 12 foot surf rod for for less than $60
AnswerID: 110391
Reply By: fozzy - Monday, May 09, 2005 at 09:31
mike
push bike shop
fozzy
AnswerID: 110394
Follow Up By: Vince NSW - Monday, May 09, 2005 at 10:59
The ones from the push bike shop are a bit short unless you mount them on the roof rack. By the way this is what I have used in the past.
Vince
FollowupID: 366928
Reply By: BenSpoon - Monday, May 09, 2005 at 10:41
a little more expensive, baut I can vouch for its durability
Bullivants Slingrig provide our site ones- rubber coated flexi fibreglass and a quick release coupling for the base. Easy to take off and put on, just get a bracket welded on your front bar or roof rack for it.
AnswerID: 110404
Reply By: Twigiee - Monday, May 09, 2005 at 10:56
Gday, I got a 12.5mm fibreglass pole from a marine shop in adelaide. It was about $30 for 3.5m from memory.
Twigiee
AnswerID: 110407
Reply By: locallaw - Monday, May 09, 2005 at 10:56
Gidday,If anyone is passing thru Mackay I have a sand pole for sale.I used it when we travelled the Simpson a while ago.
Seeya Locallaw
AnswerID: 110408
Reply By: Member - Davoe (WA) - Monday, May 09, 2005 at 14:47
any safety gear/mining supplies shop
AnswerID: 110453
Reply By: Member - Luxoluk - Monday, May 09, 2005 at 15:50
I use a piece of orange electrical conduit which I mount into a 3/4 piece of pipe mounted on the bullbar. The conduit is sleeved at one end so it can be cut to length and sleeved together when required. Very flexible and cheap. Use duct tape to hold in place. Cheers
AnswerID: 110464
Reply By: Member - Mike - Tuesday, May 10, 2005 at 07:21
Thankyou everyone who replied - you have given me the info required - thanks
Mike
AnswerID: 110572
