Twine Shower in 2004 Nissan Patrol 4.2 intercooled Turbo
Submitted: Monday, May 09, 2005 at 19:40
ThreadID: 22823 Views:3164 Replies:7 FollowUps:5
Bought myself a Twine shower to fit a 2004 Nissan Patrol Intercooled Turbo Deisel but find that Nissan have fitted the ABS where the Heat Exchange Unit & pump would normally go.
Has anybody worked a way around this problem, i.e. types of brackets that will stand a hammering on corrugated roads.
I have a Dual Battery system so any spare room appears to disapeared.
Reply By: deepwood - Monday, May 09, 2005 at 19:52
They don't have to mount in the engine bay. You could mount it in a protected area on the chassis rail.
AnswerID: 110514
Reply By: Member - JohnR (Vic) - Monday, May 09, 2005 at 19:57
Johno, not sure where the ABS system is, but I installed ours on the firewall using the originally equipment Nissan heater hoses, just one reversed onto the in-firewall fitting. I sort of thought the ABS is where I have my compressor. I can take a piccy if you really needed it..........
AnswerID: 110517
Follow Up By: Old Johno [NSW] - Monday, May 09, 2005 at 20:21
The ABS pipework now sits where the Shower used to go on both the fire wall & the original pump placement positions
FollowupID: 367015
Reply By: peterK - Monday, May 09, 2005 at 20:43
I mate of mine at the same problem. I cant see him at the moment but he had the guys at Taren Point Service Center make up a bracket for it. Seemed pretty solid and I know it has survived a few trips, including the Cape.
If you are interested just give them a call - Mike is probably the one to ask
AnswerID: 110522
Reply By: ADM - Tuesday, May 10, 2005 at 08:53
Have a look at the link below, this shows several shower set ups in 4.2 GUs.
http://members.optusnet.com.au/~grungle229/Patrol/shower.html
Hope this helps.
Ashley
AnswerID: 110584
Follow Up By: madcow - Tuesday, May 10, 2005 at 08:55
PM me direct and I can send you my setup dave.charlton@ap.effem.com
FollowupID: 367056
Follow Up By: madcow - Tuesday, May 10, 2005 at 08:56
Mine is an 10/03 model though.
FollowupID: 367058
Reply By: flappa - Tuesday, May 10, 2005 at 08:55
MInes not a Diesel , but its a 4.5 Petrol with ABS (GU Ti).
Mine is mounted on the firewall with customer brackets.
It can also be seen on Grungles website.
AnswerID: 110586
Reply By: Michael ( Moss Vale NSW) - Tuesday, May 10, 2005 at 13:23
If you dont have a winch and have an original steel bull bar you can mount it on the removable plate bolted to the base of the bull bar between the chassis rails, in front of the radiator... Michael
AnswerID: 110611
Reply By: 10 Para (Qld) - Tuesday, May 10, 2005 at 15:51
Got mine under the ARB bull and also have warn 9000lb winch, i had an extra large one made as the first one was not hot enough at 1500rpm we have 4.8 petrol and was told that they run a little cooler anyway works great where it is and as i say its about another third longer than the standard one
AnswerID: 110641
Follow Up By: flappa - Tuesday, May 10, 2005 at 15:56
Funny that.
I was told the petrols run a heck of a lot hotter (for shower purposes) then the diesels.
Mine is a 4.5 Petrol.
I was told when trying to fit mine , that the longer the heater hoses required the colder the water will be . . . ie shorter the better.
End of day . . . doesn't matter , sounds like you have a workable solution regardless.
FollowupID: 367096
Follow Up By: Michael ( Moss Vale NSW) - Thursday, May 12, 2005 at 14:09
Hey 10 para, thats a fish, not a heat exchange LOL.
FollowupID: 367412
