DUAL BATTERY SOLENOID
Submitted: Monday, May 09, 2005 at 21:21
kelpie
How good is the Redarc 100 amp 12VDC SB112 Solenoid/isolator.
I want to use a solenoid under the bonnet in a 2001 Prado and run 6ml B&S cabel to a battery box in the rear. I will be running a 6oltr Engle combo fridge/freezer.
Can anyone suggest a better solenoid or is the Redarc smart solenoid the way to go.
I did contact ARB in
Brisbane however their smart solenoid was about $240 dollars compared to the Redarc for $179 as advertised on E-BAY.
Reply By: Moggs - Monday, May 09, 2005 at 21:37
Yes, the Redarc is a good bit of kit - it is widely used and does the job
well. I use one to charge an AGM in the rear cargo area - you can also wire it up to parallel the batteries if needed for starting. I would recommend the Redarc - they are bulletproof.
One thing though, $179 seems a bit steep. You should be able to pick them up between $120 and $150 (at the most)
110533
Follow Up By: Member - Jimbo (VIC) - Monday, May 09, 2005 at 22:03
Yeah,
What Moggs said.
They work extremely
well, but the price you are talikng is
well over the odds.
Jim.
367038
Follow Up By: Member - Stan (VIC) - Monday, May 09, 2005 at 22:19
5 delivered on ebay
367044
Follow Up By: Member - Stan (VIC) - Monday, May 09, 2005 at 22:20
5 delivered on ebay </a?
367045
Follow Up By: Member - Stan (VIC) - Monday, May 09, 2005 at 22:22
Try again...
$135 delivered on ebay (item no: 4547004800)
367046
Reply By: Member - Stan (VIC) - Monday, May 09, 2005 at 22:01
Got Redarc installed last week. I was told that it is better than ARB 1314 model
one asit is fully automatic... You should be able to get redarc for around $140
110543
Reply By: Member - Hugh (WA) - Monday, May 09, 2005 at 22:15
Hi Kelpie,
Redarc is "all good mate" - just like the beer ad.
As mentioned, you should be able to get much cheaper than you've been quoted. I paid $100 (trade price) about 12 months ago.
Hugh
110546
Reply By: Mainey (WA) - Monday, May 09, 2005 at 22:33
Kelpie,
I asked the same question of redark direct, and recieved an email from them stating that their system did work better with two "identical" batteries than it did with two different batteries, so if you have two identical batteries it will be perfect for you.
The price is way over the top as you can get a brand new Rotronics isolator for about that price and they are guaranteed to work with two different types of batteries.
There are many posts on the
forum both for and also against solenoids v electronic isolators. Over the years I have had both in my vehicle, obviously I changed for a reason, ask him why he is selling his ?
110549
Reply By: Alan S (NSW) - Thursday, May 26, 2005 at 14:06
Redarc 100 amp isolator available on ebay now for $109 + $10 postage
Item number: 4550624183
113008
