AnswerID: 8187 Submitted: Monday, Nov 04, 2002 at 00:00
Allyn (member)
replied:
Desert - one good turn deserves another.
Main tank sits under rear passenger floorspace and aux is above spare wheel well.
I have a 4WD systems replacement for auxillary which required a spare wheel carrier in place before fitment. (www.4wdsystems.com.au)
It holds 200 litres + (give or take 10) and if that's what you are after then I believe it's the way to go as it holds slightly more than the others on offer for the same price. Others are offering 170 litres .
It's structurally sound and takes a bashing no problems at all.
Any questions then just get back to me
Reply 1 of 2
FollowupID: 3905 Submitted:
Tuesday, Nov 05, 2002 at 00:00
Allyn (member) posted:
Desert
Tank sits beautifully underneath and is far higher than your spare wheel would be currently. You cannot see it from behind at all.
The extra 20 litres or so didn't concern me as you don't need to fill the tank to the brim unless travelling far enough to need it, in which case you would have a jerry can with same weight anyway and it's really only 20kg isn't it. You will need beefed up
suspension before this mod both because of the additional weight and due to the spare wheel and carrier being further back on your vehicle. I added polyair springs also but not really necessary.
FollowUp 2 of 3
FollowupID: 3907 Submitted:
the weight is far better being under the car than anywhere where it affects your centre of gravity ie. sitting on top of a roof rack. How often you fill the tank to the brim is entirely up to you. I fill mine every time but I live a lot further from nearest town that I would visit and use a fair bit of the stuff it holds. It will pay off eventually though, for example I was able to complete Gibb River including
Kalumburu without refilling. We paid $1 per litre in
Kununurra and the rest of my crew paid $1.50 at Drysdale and
Kalumburu. I debated the issue over and over and in the end thought that if I couldn't make my mind up then I would go for it. Can't say as I'm unhappy.
FollowUp 3 of 3
