Rancho 9000
Submitted: Tuesday, May 10, 2005 at 17:37
ThreadID: 22853 Views:1801 Replies:2 FollowUps:5
Hey Guys....I just had a look today to see what shocks I have and found they are the adjustable rancho 9000 I found the control knob but I can't see what setting is what....can someone maybe shed some light on this for me....thanks
Reply By: DukeAtty - Tuesday, May 10, 2005 at 20:58
turn em all the way anticlockwise and they are on softest and opposite for hardest...
AnswerID: 110703
Follow Up By: Tuco - Tuesday, May 10, 2005 at 21:58
I don't usually 'fiddle' with the settings on my 9000's - having established not long after I fitted them that '4' was fine on the front and '3' was ok on the rears.
Thats how they have been for over 2 years.
Recently however we hitched a caravan to the Surf and I attempted to change the rears from '3' to '4'. NO LUCK!! I am unable to move them beyond the range 1-2-3.
Anyone else had this problem??
FollowupID: 367158
Follow Up By: DukeAtty - Tuesday, May 10, 2005 at 22:14
Are you sure they are 9000's and not 5000's... Because they normally go in increments of two which would mean that you number 3 is actually number 5 which is the maximum....
Sorry if thats a dumb comment, but my 9000's go in lots of two...Which would mean 5 settings...
FollowupID: 367161
Follow Up By: Tuco - Wednesday, May 11, 2005 at 09:40
Definitely 9000's - used to have 5 settings, but now can't get the rears past '3'. Fronts are on '4'. I feel that if I force the adjusters they may break.
FollowupID: 367198
Follow Up By: Truckster (Vic) - Wednesday, May 11, 2005 at 10:12
Its common for them to sieze up.. its another failure with them. the oring behind the adjuster which is a cam screw, just gets crap in them, and they sieze. Try for warranty on em. but since they are 9000 not 9x you will have little hope.
FollowupID: 367210
Follow Up By: Tuco - Thursday, May 12, 2005 at 10:57
Thanks Truckster - I thought something like that may have happened.
Just went through my receipts - bought them in October 01 - now 3 1/2 years old and some 80,000 K's on them.
Well out of waranty I would have thought.
Still work fine - no leaks - but cant adjust any 'harder' - only can go 'softer' .
Almost sounds what my wife is up against! LOL
cheers ...
FollowupID: 367387
Reply By: Tuco - Wednesday, May 11, 2005 at 20:43
cheers ...
AnswerID: 110902
