Imperial to Metric Tyre Conversion
Submitted: Tuesday, May 10, 2005 at 18:34
ThreadID: 22857 Views:12337 Replies:4 FollowUps:1
What is 7:50R16 in metric and would there be any variation in the speedo
rojac
Reply By: Matt (W.A.) - Tuesday, May 10, 2005 at 20:02
Rojac,
Try this link Tyre Converter it has a few other interesting Converters too,
Hope it Helps
AnswerID: 110687
Reply By: Member - Mark- Tuesday, May 10, 2005 at 21:59
rojac
7:50r16 is the same as 235:85:16
mark
AnswerID: 110716
Follow Up By: Member - Davoe (WA) - Wednesday, May 11, 2005 at 10:42
no it doesnt
FollowupID: 367222
Reply By: old-plodder - Wednesday, May 11, 2005 at 08:20
7.5" x 25.4mm per inch = 191mm wide.
tyres are 32" od = approx 810 od.
normally a LT rated tyre like 8, 10 or 12 ply plus.
235/85/16 is a common replacement.
also 32" od (generally 804 to 808 OD) but a bit wider by 45mm.
7.5"x16 were a common size on 5.5" and 6" x 16"dia split rims.
I think 235/85/16 may be limited to 6" wide rims or wider so check your rim size.
Has been a thread discussing this, but not sure of the number :-(.
AnswerID: 110760
Reply By: Redback - Wednesday, May 11, 2005 at 08:47
The tyre conversion won't do the conversion from 7.50/16 to what ever needs to have the height & width measure as well still good for the other stuff though, also the 235/85/16 are for 7" rims standard tyre for the Land Rover Defender on 16x7" rims.
Baz.
AnswerID: 110763
