Waeco CF-50
Submitted: Saturday, May 14, 2005 at 05:20
scottcamp
Just a quick question about the waeco CF-50. When the fridge is running should you be able to feel the air from the fan. One side of the fridge vent is cold the other is hot, i know this is correct. But if you put your hand next to the hot vent i cannot feel the air from the fan, is this normal? The fridge seems to run ok, maybe looking for fault.
Scott
Reply By: Member - toohey - Saturday, May 14, 2005 at 09:13
gid'ay scott
mines the same, works perfectly.
regards toohey
111260
Reply By: Muddy 'doe (SA) - Saturday, May 14, 2005 at 16:00
My CF-40 is same. No real air flow. It is just a vent I think.
Muddy
111272
Reply By: scottcamp - Saturday, May 14, 2005 at 19:17
Your right, i am just looking for fault. Just filled it with warm beer last night and this morning its sitting at zero degrees. Looked into the cold vent grill with a torch and could see the fan turning, so silly question, alls
Scott
111281
Reply By: dieselman - Monday, May 16, 2005 at 22:58
G,day
I have a cf-50, does the same thing - Can't feel airflow but is hot on one side cold on the other. Hope this helps
111549
