GQ power windows
Submitted: Saturday, May 14, 2005 at 18:39
brumac
My drivers door power window motor does not stop spinning when window reaches the top.Only happens on auto wind up.Has any one had this problem before.
Reply By: Truckster (Vic) - Saturday, May 14, 2005 at 20:00
Does it go up without hesitation? Theres a plastic gear inside that craps itself regularly.
111284
Follow Up By: sevo - Saturday, May 14, 2005 at 22:03
truckster is spot on happens frequently, plastic gear stips and causes window to fail.
367665
Follow Up By: jendav - Monday, May 16, 2005 at 11:31
Had the same problem with my Ti, and tried many things, what fixed it was to remove the assembly completly and cut a thin piece of plastic sheet, around .25-.05mm to act as a packer under the mechanism. what happens is that the metal tabs on the winder part create a rounded edge on the plastic part, therefore it doesnt grip but slides out an keeps going round and round. By installing a lifting packer, it makes the metal tabs grip in the holes again.
sorry if this is a bit vague, going from memory.
367769
