Bush tyres - got em
Submitted: Friday, May 20, 2005 at 13:33
Member - Davoe (WA)
After numerous flats and a wrecked tyre I decided I needed tougher easier to fix tyres for my 80 for bushwork around Kalgoorlie and as it turned out the club newsletter ( that I joined last break) had 6 splitties with Mrf super traction 12 ply rag tyres for just 100 dollars the tyres are pretty worn but should do for a while. Another bonus is the cost of tyres is between 140 and 160 and as I dont have much bitumen work to head bush it should cut costs down on bush driving (320 dollars on tyres and repairs in the last 3 trips) now while the wallet is out perhaps I will look at an Engal
Reply By: Rod W - Friday, May 20, 2005 at 14:52
Hey! ain't you in the mining industry earning big bucks?
What's the bet most of the tyre damage will be through the sidewalls where there ain't no 12 plys?
112086
Follow Up By: BenSpoon - Friday, May 20, 2005 at 15:07
I heard that rumor too somewhere.... along with the all politicians are honest, and all coppers are good honest people.
368446
Follow Up By: old-plodder - Friday, May 20, 2005 at 16:26
May still only be 2 ply walls, but I bet if they are 12 ply they will belimited to 80psi or 100psi for the extra load carrying capacity.
And to get that there has to be a lot more rubber in the sides!
So maybe they won't stake so easily as 6 ply tyres.
368454
Follow Up By: Member - Davoe (WA) - Friday, May 20, 2005 at 16:49
They are not the tyres I would have bought but I will try them out they are 4 ply nylon sidewalls. My tyre of choice is no longer availablre being the dunlopdr2. Oh and thanks for
the tip Ben - intrested in going for a drive tomorrow?
368455
Follow Up By: Member - Davoe (WA) - Friday, May 20, 2005 at 16:53
Oh! and just in case you think no one listens to you rod(besides your kids) The reason for the splitties and rags was after your post. I also went out and spent 300 on tyre pliers, Quality levers patches both tube and tyre as
well as xtra tubeless worms
368456
Reply By: Skinnydog - Friday, May 20, 2005 at 20:24
Just a question? I thought rags were crossplies and if they are crossplies then should'nt they have 12 plies in the sidewall as
well?
Skinnydog
112120
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, May 21, 2005 at 19:18
unsure. I think these like I said these tyres were not my tyre of choice I think they are kind of a semi rag tyre - tougher than radials but not as tough as the real deal. they have 6 ply nylon tread and 4 ply sidewalls and some how that makes them 12 ply-should still be tough enough and being on split rims it makes puncture repairs and removing tyres a cinch
368552
