prado mags to nissan patrol
Submitted: Sunday, May 22, 2005 at 21:19
ThreadID: 23214 Views:6824 Replies:5 FollowUps:5
I was wondering if any body can tell me if Toyota Prado mag rims will fit a Nissan GU Patrol thank you Dave W.
Reply By: Tbreak - Sunday, May 22, 2005 at 21:55
Which model Prado? 90/95 series were 16 inch. 120 series are 17 inch.
AnswerID: 112364
Follow Up By: Member - Dave W (VIC) - Sunday, May 22, 2005 at 23:49
Thanks Tbreak for your reply I think they are 90/95 series they were advertised on ebay as 16x6
Benwool
FollowupID: 368639
Follow Up By: Member - Dave W (VIC) - Sunday, May 22, 2005 at 23:53
Dave W
FollowupID: 368641
Reply By: awill4x4 - Sunday, May 22, 2005 at 22:37
I think you will find that although the bolt holes are the same pitch diameter that the centre hole on the Toyota is slightly smaller than that of the Nissan so it would be well to measure both to make certain 1st.
Regards Andrew.
AnswerID: 112371
Follow Up By: Member - Dave W (VIC) - Sunday, May 22, 2005 at 23:52
Thanks Andrew I wont be able to measure the Prado ones as I seen them on ebay Dave W
FollowupID: 368640
Reply By: Member - Phil G (SA) - Monday, May 23, 2005 at 09:01
Like andrew said the centre hole is probably a fraction too small. But I know people who have ground it out a little to make Toyota wheels fit. Offset and PCD are the same.
The 16x6 Prado wheels are a dime a dozen, as everyone takes them off the RV. The 16x7 are much more popular.
Better option if you want 16x6 is to look for a set of Navara wheels.
AnswerID: 112395
Follow Up By: Member - Dave W (VIC) - Monday, May 23, 2005 at 22:16
Thanks Phil Ithought I would chase up 16x6 as I have just bought the Nisan Patol Cab/C and it has a new set of tyres on it but with split rims looks ugly as I am a fitter and turner I could bore out the centre hole no probs thanks for your info
Dave W.
FollowupID: 368740
Reply By: Utemad - Monday, May 23, 2005 at 22:09
Wouldn't they be the wrong offset?
AnswerID: 112508
Follow Up By: Member - Dave W (VIC) - Wednesday, May 25, 2005 at 23:25
Thanks for your reply utemad I think I will stay with rims and tyres I already have until the tyres wear out then I will purchase a set of nissan rims that suit
FollowupID: 369089
Reply By: Member - Phil G (SA) - Tuesday, May 24, 2005 at 22:04
Dave,
The backspacing of the 16x6 Prado wheels is about 115mm. Might be worth comparing to your Nissan wheels to know for sure about the offset.
AnswerID: 112687
