2001 Toyota 100 series 4500 petrol
Submitted: Monday, May 23, 2005 at 09:56
Member - Kim R (QLD)
G'day everybody, has any one out there had any experience re better economy and bottom power for the above. So far I have a K&N air filter and a Hiclone, with these I return around 17liters per 100klm around town and 20 liters per 100klm towing a camper-o-matic trailer.
Does any body make a chip?
Extractors, yes or no ?
Yes I know that a 4500Turbo Deisel would solve my problems but at the time of purchase a difference of $12,000 buys a lot of petrol.
thanks
Reply By: Rod W - Monday, May 23, 2005 at 11:53
Yep that about right. Mines without the K&N and Hiclone. But I do have extractors.
112413
Reply By: Member - Stan (VIC) - Monday, May 23, 2005 at 12:29
Unichip will give you more power low down and more torque, it also
might impove a fuel economy.
Link
112418
Reply By: Member - DOZER- Monday, May 23, 2005 at 13:01
Unichip makes a big difference to this motor...know someone who had one fitted...makes motor run more efficient with trmming of fuel and ignition maps....get extracters fitted first then a unichip....or....put it on gas and start saving big time....
112423
Reply By: BenSpoon - Monday, May 23, 2005 at 15:09
Extractors improve it noticeably, and whilst you're at it, get a larger diameter mandrel bent exhaust.
I took off my hiclones and economy has improved slightly.. I got 367km on the full main
tank thru to first signs of the empty warning light with hiclones in, and 398km with them out, driving the same patch of road, a calm day and same speeds both ways. Read that how you like.
After seeing improved air flow and air filtering results for the cheap AC delco paper air filters, my finer filter will be the next thing to go. Althought K&N is markedly better than the finer filters, the AC Delco still came out ontop of it in the particular results I saw. Certainly something to check into.
If you are looking to mod the actual engine, not just ECU, Look into mods for the straight 6 Toyota/Lexus Soarers- they have the same block setup as cruisers, with the exception that theirs is alloy. Of course, if you do find something, share and share alike.
If you get a chip, make all adjustments to draw and air flow first-
snorkel, filter, hiclones, exhaust etc. then get it done. If you do go down this path, let us know the outcome- I am keen to find if it is worth the cost.
112432
Follow Up By: Member - Kim R (QLD) - Tuesday, May 24, 2005 at 09:31
Thanks everyone I have contacted the
Brisbane coy for Unichip and will proceede down that parth. Will also search around for the right breed of extractors and look at them. Do not really want to change the exhaust system from extractors back as I have had to hang up so far in 60,000klm of bush driving.
Any positive out comes I will certainly post. Thanks again.
Kim.
368773
