Condition of Geraldton Bore
Submitted: Monday, May 23, 2005 at 14:33
Cam A.
Gidday, does anyone know if the
Geraldton bore has drinkable
water in it? If so what is the diameter of the
bore and how far down to the
water is it.
Cam
Reply By: Max - Sydney - Monday, May 23, 2005 at 17:11
Was fine in 2001, but
bore only about 50 mm diameter. Someone had put a small tin on a string and you could draw up 100 mm at a time. Would need to take a pump and say garden hose to draw it up - not very deep, maybe 3 metres.
Max
112448
Reply By: Andy C - Tuesday, May 24, 2005 at 17:32
Please don't rely on
Geraldton Bore for great quantities of
water. The
bore lining is probably 150mm and you can only get a jam tin down and out.
When I was there 2003, the jam tin on the end of the rope someone had kindly left behind disappeared when someones dodgy knot let loose! Quality of
water - unknown but in an emergency, any
water (with boiling) will be better than none!
112623
Follow Up By: Cam A. - Wednesday, May 25, 2005 at 10:44
Thanks guys, We will not be relying on the
bore...!
Burppp
Cam
368923
