80 series fuel tank pressurizing
Submitted: Thursday, May 26, 2005 at 11:05
Hairy
Has anyone ever had trouble with a 1996 petrol 80 series building up a lot of pressuer in the fuel
tank? (too much pressure!)
Where do I look after the carbon canister if ther is no obstruction there?
Hairy
Reply By: bundyman - Thursday, May 26, 2005 at 11:36
Hairy,
Check the breather on the fuel cap mate. I know our work 75 Series (diesel) utes get the little brather hole blocked occasionally and then you actually starve the motor of fuel as the
tank drops to about 1/4
tank - purely due to the vacuum created. With a petrol you'll have the expansion problem which mighten be able to escape hence the high pressure. Just my thoughts.
Hughesy
112979
Follow Up By: Hairy - Thursday, May 26, 2005 at 13:58
Cheers for the thoughts but apparently they dont have a breather hole and are suposed to have a little pressure in them because of the fuel injection.
Thanks anyway
369172
Reply By: BenSpoon - Thursday, May 26, 2005 at 11:47
Check that the fuel cap is genuine- If not, head to a wreckers. If it is, might be worth cleaning it out.
112980
Reply By: Moose - Friday, May 27, 2005 at 13:31
How do you know there is too much pressure?
113171
Follow Up By: Hairy - Monday, May 30, 2005 at 08:49
After unscrewing the cap I pressed the little flap down inside the filler to release some of the pressure and fuel spewed out and covered me!
Great stuff in your eyes!
369607
