available tyre sizes
Submitted: Friday, May 27, 2005 at 19:02
ThreadID: 23360 Views:3293 Replies:6 FollowUps:4
i have 245x 70 16 a/t's on a rodeo duel cab which are getting close to replacement,i have a trip to birdsville & the cape planned in the next 12 mths , i would like to increase the size but also have a size tyre that can be bought in the bush easily if needed, does anyone have some advice to help me please
Reply By: Willb - Friday, May 27, 2005 at 20:14
Hi sshep, have a look at the tyre placard or the owners manual they should list aternate sizes.
My Jackaroo come with the same size 245/70/16 but I am also able to fit 225/75/16 or 235/70/16 which have a similar diameter.
I am going for 225/75/16 BFG which is more common and cheaper.
Will
AnswerID: 113240
Follow Up By: sshep - Saturday, May 28, 2005 at 14:54
thanks willb, i checked the manual & placard but they only show the one size thanks
FollowupID: 369465
Reply By: Member - Peter D M - Saturday, May 28, 2005 at 07:50
hi sshep,
245x70 r 16 = 754mm standard
245x75 r 16 = 774mm 10 mm increase ground clearance, same width
265x70 r 16 = 777mm 12 mm 20mm wider
265x75 r 16 = 804 mm 25 mm 20mm wider
on my rodeo i run on road 31x10.5 r 15 = 772mm
off road 265 75 r16 on standard rims but with 40mm suspension lift and plastic gaurd liner trim.
there are hundreds of tyre combinations and most country dealers buy in to order.
unless they are standard toyota - nissan that locals tend to have.
regards peter
AnswerID: 113284
Reply By: sshep - Saturday, May 28, 2005 at 15:05
peter dm thanks for the sizes & dia's thats just what i needed to know i think ill go for the 245 x 75 that will give me a bit more clearance with a 50mm suspension lift but hopefuly not effect the on road handling to much.
AnswerID: 113323
Reply By: Dennis (Mackay) - Saturday, May 28, 2005 at 17:14
http://www.1010tires.com/TireSizeCalculator.asp
AnswerID: 113355
Follow Up By: sshep - Tuesday, May 31, 2005 at 20:25
unreal dennis , i have never seen a tyre site like it. the calculator is great. thanks for that.
FollowupID: 369867
Reply By: cmilton54 - Saturday, May 28, 2005 at 18:21
sshep
Depending on what year Rodeo, latest model have 111 load index not 107 which means you need 111 or greater. Only made at moment in Bridgestone, BFG I think Cooper is in process of bringing in that load index as well
Charlie Milton
AnswerID: 113363
Follow Up By: sshep - Tuesday, May 31, 2005 at 19:23
thanks cmilton54 i didnt realize the load index was altered, i'll check it out with the dealer
FollowupID: 369857
Reply By: Dennis (Mackay) - Tuesday, May 31, 2005 at 22:04
FYI
Holden Rodeo dual cab (2004)
BFG AT 245/70/16, 45000km old
Driving on mine sites and highways.
Tonight at 110km/h the tread separated completely from the belting on the right hand drivers side (was previously on the rear). Almost like you see recaps when they come apart.
The other 3 look visually OK but all 4 are getting the flick tomorrow just in case.
Have been good tyre for the primary reason I chose them (cut resistance) but terrible in the wet on bitumen.
AnswerID: 113820
Follow Up By: sshep - Thursday, Jun 02, 2005 at 20:09
i read your thread dennis bfg's were one of my options,iam not sure if it was tyre pressure or slow leak as one person replied. i have heard of it before.thanks for the warning thu hope you have better luck with your new set regards shep
FollowupID: 370115
