WIRING UP SPOTLIGHTS ON NEW HILUX
Submitted: Friday, May 27, 2005 at 20:05
time waster
checked rear of head light and found all wires live all the time without yhe high beam on,where would i get the wire to switch the relay?they must use ground as the switch thanks
Reply By: drivesafe - Friday, May 27, 2005 at 20:40
Hi time waster, you have negative switched headlights.
If you have the standard three pin socket on the back of you headlight globe, when you look at the plug there are two large female terminal on either side with the slots running vertical and across the top is the third terminal running horizontally.
This last terminal at the top is the high beam wire and the one you need to connect to.
Run a wire from the high beam wire to one of the coil terminals on the driving light relay and run another wire from the other coil terminal fo the relay to battery positive and the the relay will now operate when ever you turn on high beam.
Cheers.
113248
Reply By: Kiwi Ray - Saturday, May 28, 2005 at 08:45
Hi Time waster
Have a good look around the head light area yuo may find a spare plug already there for some extra lights. You may just have to fit a switch to turn them off to make them legal.
Just a thought.
Ray
113288
