Isuzu Mu Gearbox - HELP!!
Submitted: Saturday, May 28, 2005 at 13:18
ThreadID: 23377 Views:5856 Replies:5 FollowUps:2
Hi there,
A while ago i recieved a reply from a couple of u guys in regards to a gearbox for a 1992 Isuzu Mu, HOPEFULLY, u are still around( MattMu & Utemad?????)
PLEASE if you or anyone can help out with info it would be most appreciated.
Not even quite sure what box goes in, been told a Jackaroo, a Holden Rodeo.....
If anyone can tell me exactly which one it is (if it is even either of those 2) i LOVE you!! (not really but I would be VERY grateful)
I am in Perth
It's a 1992 Isuzu Mu
5 sp ( yes they CAN be blown up!!)
2.8 Turbo Diesel
Not sure if it's possible to contact me via my personal email..???
If so let me know & i'll give it out..
thanks & hope some one can tell me..
from
Broken BlooMoo... BOO HOO
Reply By: Utemad - Saturday, May 28, 2005 at 13:54
I want you to know that I am happily married!!!
Unfortunately I have misplaced my Rodeo manual. Although I can tell you that my manual does state the the manual gearbox in the 1997 Rodeo/Jackaroo range was the same whether it was behind the 2.6 petrol, 3.2 petrol or the 2.8 turbo diesel. So I would imagine that it would fit behnd yours even with the age difference. If you try a wrecker they would most likely know.
Good luck.
AnswerID: 113314
Follow Up By: Utemad - Saturday, May 28, 2005 at 18:08
MUA rings a bell. I think that is either all or part of the gearbox designation.
Then again it could just be a jumble of letters LOL
FollowupID: 369493
Reply By: Member - Bruce and Anne - Saturday, May 28, 2005 at 16:07
I had my gear box replaced on my 1993 3.1 MU ( by the warranty company) and Iam pretty sure it was out of a Jackaroo.
Have you joined our club yet www.clubisuzu.com there is probably an answer on it.
Cheers Bruce.
AnswerID: 113336
Reply By: Cracka - Sunday, May 29, 2005 at 19:05
Mark's Adaptors would no doubt be able to give you a definetive answer I'd reckon Blumu Wahoo. The Rodeo is the same chassis as the Mu/Frontera so you'd think the tranny'd be the same.
Do what I do and spend the money first, then ask!
Cracka
AnswerID: 113482
Reply By: Member - Matt Mu (Perth-WA) - Monday, May 30, 2005 at 12:07
Blu Mu its the Jackaroo and as said its the MUA5 but these had heaps of bolt pattern, just not here in Aust. The bolt pattern for the 3.1 Jackaroo and 2.8 are identical, having swapped my 2.8 motor for the 3.1...same gbox.
So you can either souce a second hand box from a MU or Jackaroo, even my dads 2002 petrol Jack box (side by side, not sure bout ratios) looked identical, except for the shift on the fly actuator!
Last time I chatted to Niel at WestWide recyclers I though he mentioned having a MU box still. Give them a try on 0894594555......Maddington.
What did yiou do to you box? Is it rebuildable? Wouldnt mind having a crack at it...just depends on the state of the internals!
Goodluck...Matt.
AnswerID: 113549
Follow Up By: Member - Matt Mu (Perth-WA) - Monday, May 30, 2005 at 12:30
ps.....from about 93 onwards the MUA5 box changed from having a slip spline on the output to having a flange. So be aware that unless you find the early box, you might need the propshaft or at least the flange drive off one and throw it on your shaft! Not a big problem at all, just a point to note!
Matt.
FollowupID: 369636
Reply By: Member - Matt Mu (Perth-WA) - Monday, May 30, 2005 at 12:32
oops brain fart.. you would need the probpsft cos the slip joint would be missing on yours, but I dont think you will have that problem...dont think WestWide had any 3.1Mus!
AnswerID: 113552
