seat options for 60 series.
Submitted: Monday, Nov 11, 2002 at 01:00
ptcrowe
I have a 89 lancruiser with a 3/4 bench
seat that my wife finds extremely uncomfortable on long trips. i was hoping for some info on what type of seats can easily be bolted into the cruiser. i had an old ford xd which i thought had some comfy seats is it possible to bolt something like that into the truck. thanks
Reply By: dave - Monday, Nov 11, 2002 at 01:00
I put a pair of SAAS seats into my troopy, no major problems, and much more comfortable than the originals
8404
Follow Up By: Member - Cruiser1 - Tuesday, Nov 12, 2002 at 01:00
Dave,
I'm thinking of doing the same thing.
Do the SAAS seats fit onto the 3/4
seat mounts?
4074
Follow Up By: Dave - Tuesday, Nov 12, 2002 at 01:00
Cruiser1, almost. For convenience I had a set of brackets fabricated that alow me to bolt the seats in from the side, (making removal much easier) they also allowed me to move the seats back a bit as the holes in the seats put it
well forward.
The brackets are like two L shaped sections made of 25mm box with a 3-4mm flat section coming off them. The flat sections mount to the existing rails and to the
seat. The two box sections go together inverted with a drilled and tapped hole in the ends for the side mounted bolt.
Oh for the ability to post diagrams.
Any way it's all legal because the rails were not moved.
I can probably organise a diagram for you if you like.
4076
Thanks Dave,
Might look into that. Sounds like a fairly easy option.
4089
Reply By: Member - Mal - Tuesday, Nov 12, 2002 at 01:00
Ptcrowe, I fitted a Volvo passenger
seat in my 60 Series. The front bolt holes on the slides lined up. Just made a bracket out of a bit of angle for the rear. As someone said recently, Volvos have got to be good for something!!! Mal T.
8424
