Dead fuel pump
Submitted: Tuesday, May 31, 2005 at 22:17
Korumburra Troopy
My 75 series Troopy 4.5l petrol has a dead fuel pump. I am told it is an in-
tank pump. Does the
tank have to come out to access the pump or is there an access panel? any advice will be welcome.
Fortunately, it is running on gas too so I am not immobile, however, last week the EFI main fuse blew and shut me down altogether. It appears to be quite coincidental, but has anyone experienced a similar problem?
Reply By: Member - Davoe (Widgiemooltha) - Tuesday, May 31, 2005 at 22:34
I am pretty sure there there is an access panel, you will have an assembly on top of the
tank which has your hoses coming in/out, Above that would be the first place I would look
113829
Reply By: Troll83 - Wednesday, Jun 01, 2005 at 09:19
I had the same thing in my commodore couple of years ago, the pump was on the front end of the
tank towards the bottom, just a couple of bolts holding it there, undo all that and make sure you have a bucket or something under there to catch the fuel coming out so you can put it back in,
mine died with a full
tank of fuel, you you are pretty empty so you don't lose to much...good luck
113862
Reply By: Member - DOZER- Wednesday, Jun 01, 2005 at 19:05
Gday
Pretty easy job if it is thesame as an 80 (no reason it wont be) there will be a hatch in the floor above the main
tank (under the second row of seats if its a 6 seater) hope you dont have too much in that area to remove...
Once opened up, u should be looking at a 17mm bolt, many 8mm ones and a couple of hoses b4 it is removeable through the top.....
HOWEVER, b4 u go that far, u should buy a mulitmeter and a workshop manual...because u can see if it is getting volts through the check connector...if it isnt getting volts, it could be other problems....also a friend bought a pump from repco and is livered it is noisy as anything....so make sure you get a quiet one....u can buy them over the net from ebay....$169...i have one and it is not noisy :-)
113952
