Site Search
Section Image
GPS INFO PLEASE
Submitted: Wednesday, Jun 01, 2005 at 21:03
robbo44
HI ALL, A LITTLE BIT OF INFO PLEASE. WE HAVE PURCHASED A GPS THE BRAND IS GPSMART. WE WERE GIVEN READINGS FOR OUTBACK AUSTRALIA AND WE ARE HAVING A PROBLEM PUTTING THEM INTO OUR GPS. THE UNIT WILL ONLY LET US PUT IN 8 NUMBERS AND ANYTHING OVER 5 DIVERTS BACK TO 5, EG:-
NSW...150.777642 -30.495672 WHEN THESE READINGS ARE PUT INTO UNIT THE RESULT IS AS FOLLOWS. 150.55554 - 30.45555. WE WERE TOLD THAT THE UNIT WE HAVE NEEDS TO BE CONVERTED TO DECIMAL NOT SECONDS. WOW WE ARE VERY CONFUSED. IS THERE SOMEONE WHO HAS THIS SAME UNIT OR IS THERE ANOTHER UNIT THAT IS SIMPLE TO USE AND IS RECOMMENDED. HOPE THERE IS SOMEONE OUT THERE WHO CAN GIVE US SOME INFO.
ThreadID: 23506 Replies: 5
Views: 982 FollowUps: 4
AnswerID: 113973   Submitted: Wednesday, Jun 01, 2005 at 21:19
Member - Chrispy (NSW) replied:
Robbo - the unit probably expects you to use the far more modern method of co-orinates.... it's called UTM. Based on a 1,000 metre gridline, all modern maps have this standard printed on them. Eastings (x-dimension) consist of 6 digits (eg: 680123) and Northings consist of 7 (eg: 5987123)
Does the unit mention UTM at all?
Our Pug Chops - Defender of the Realm'00 Land Rover Defender TD5
'96 Mitsubishi Delica 2.8TD
'95 Nissan Patrol GQ TD42T
'91 Nissan Patrol GQ RB-30
Our property: http://www.omaroo.net
Reply 1 of 5
FollowupID: 370009   Submitted: Wednesday, Jun 01, 2005 at 21:41
robbo44 posted:
Hi Chrispy, Many thanks for your reply. There is not mention of UTM in unit or book. Do you live near or around Newcastle NSW? we might be able to meet, you sound as if you know a bit about GPS's.
AnswerID: 113990   Submitted: Wednesday, Jun 01, 2005 at 21:54
dja replied:
The spec and 'Tech Support' is available at http://www.fortuna.com.tw/GPSmart.htm , but I saw no usefull info there to assist your dilema.
It may be that your desired position is
-30 29 44.4192 E
150 46 39.5112 S
I deduced this from entering your point into Oziexplorer and then changing to deg min and sec which is what I reckon your unit is looking for.
A normal way to interpret the format is to create a waypoint at your current position and then compare this to what is on a map. This should provide you with a quick answer.
I'd suggest that you carefully put the instrument in the next Trading Post or bottom drawer of the filing cabinet and invest in a new $200 Garmin Etrex or $300 Garmin Etrex Legend or Magellan equivilent from Brian at http://www.gpsoz.com.au/ or similar reputable dealer.
I trust this assists
dja.
Reply 2 of 5
FollowupID: 370016   Submitted: Wednesday, Jun 01, 2005 at 22:05
robbo44 posted:
g'day dja, many thanks for your info i will try what you have said about putting in my waypoint and see what it reads. The place we purchased the unit from will take it back and refund, as we have already been to test their knowledge and they did not know anything about the unit at all , they only sold them.its a worry. I will let you know how we got on.
AnswerID: 113998   Submitted: Wednesday, Jun 01, 2005 at 22:13
kgarnett replied:
Hi Robbo,
I have the same GPS and have no problems.
You can specify the format in the GPS setup.
The options are :
DDD.DDDDD*
DDD* MM.MMM'
DDD* MM' SS.S"
eg if position is 150Deg 30 Mins 45 sec then the options are:
150.5125 (ie 150 + 30.75/60)
150* 30.750' (150* 30 + 45/60)
150* 30' 45.0"
Take a look at how it shows your current position to determine the expected input format.
Please also note that you can also set the datum in the setup- the options are ADG 66,ADG 84,NZD 49,WGS 84.
Hope this helps rather than confuses !
Reply 3 of 5
FollowupID: 370035   Submitted: Wednesday, Jun 01, 2005 at 23:30
Play Rough posted:
I've also have the same unit as a cheap interface to oziexplorer via a comms cable i got from expansys. and it seems to work well
Craig
FollowUp 1 of 2
FollowupID: 370046   Submitted: Thursday, Jun 02, 2005 at 07:33
Big Woody posted:
Hi Robbo,
kgarnett has hit the money with his reply mate. You will find that you can change the format for entering co-ordinates.
Personally, I like using the digital format that your GPS is currently set at but when it comes to sharing co-ordinates I change the setting on my GPS to hh:mm:ss.s as that seems to be what most people are using. I then enter the waypoints and set my GPS back to using the digital co-ordinates and the waypoints stay where you have set them.
Also check that your datum is set to the same datum as the person who has given you the co-ordinates. It seems the most common at the moment is WGS 84.
Don't sell your GPS, just change the setting and it will do exactly what you are trying to do.
Brett
FollowUp 2 of 2
AnswerID: 114045   Submitted: Thursday, Jun 02, 2005 at 08:09
Member - RockyOne replied:
Hi Robbo,Hope you will do your next post in Lower Case,as most folk do.Kind of hard on the eyes all that heavy Upper Case (Capitals in old lingo)..But (our teacher in a little old one teacher school out in the sticks insisted,never start a sentence with but..here goes) anyway,I hope you get the info req..How did we ever work all our gadgets and more important,buy the right ones in the first place,without getting a "lemnon" before www.
My 2000 TJ & Aussie Swag camper at beautiful Five Rocks nth of Rockhampton Qld
Click Image to Enlarge
Life is only froth 'n bubble.Two things stand like stone..Kindness in anothers trouble.Courage in your own
Reply 4 of 5
Activities Index
Port Stephens, Nelson Bay Dunes & Dolphins Port Stephens, Nelson Bay Dunes & Dolphins
Lower Nth Coast / Newcastle - NSW
Discover the beautiful North Coast region of Port Stephens.
Kangaroo Valley Package Kangaroo Valley Package
South Coast - NSW
Join us on an adventure weekend of horseriding through the picturesque rainforest and mountains of K
Team Building Cooking Class For Up To 15 People Team Building Cooking Class For Up To 15 Peop
Sydney - NSW
The perfect idea for your next work team building event!
Harley Trike Winery Tour For 2 - Sunshine Coast Harley Trike Winery Tour For 2 - Sunshine Coa
Sunshine Coast - QLD
Now this is a winery tour with style - much more fun than on a bus or in a car.
Book Now - Things To Do
AnswerID: 115638   Submitted: Tuesday, Jun 14, 2005 at 03:47
Niko replied:
GPSMart only allows you to read and input lats and longs, there is no datum format available in UTM. In other words if you are familiar with reading in metres, forget it!
Reply 5 of 5
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
