FollowupID: 4113 Submitted:
Wednesday, Nov 13, 2002 at 00:00
Oziexplorer posted:
Savvas under *NO* (shouting from top of hill) would you want to use a diode between the battery and the cigarette lighter. You cannot afford to loose .6 volt. You would need a Schottky diode, and for one of the required capacity would cost to many dollars. Schottky diodes are not normally used over forward currents of 1 amp. However, even a Schottky diode would not satisfy me. Any charge loss is to much.
The battery will not get properly charged to peak voltage.
It is no big deal to put a Bosch type mini-relay directly from the ignition circuit.
Personally, I would much prefer to see a better quality polarised plug and socket to connect that battery to the vehicle to charge. Cigarette lighters are generally shockers.
