FollowupID: 4168 Submitted:
Friday, Nov 15, 2002 at 00:00
Janset posted:
Hi guys.
As you would no doubt have noted from my past posts, the compressor path is well trodden by me. I have had A/C compressor (which I again have), Blue tongue, ARB, which I now use for my diff lock and a Truck something or other from Marlows which I had a very long time ago.
So what is my opinion. A/C is the best way to go if you have the room or are prepared to spend a LOT of time getting one to fit.
Of the 12 volt type, plan for the future if you intend to fit air lockers sometime in the future then get an ARB.
If no to all the above then the Blue tongue is the only way to go, and if you have zillions of dollars then the double blue tongue.
The benefit of the Blue tongue/s is that they are open fan cooled motors that will run all day and do not suffer from thermal cut outs. I am told they are so fitted for protection but I have never had one overheat or stop for me.
Their strong point of never overheating is also their down side in that they are open, and as such are open to to the ingress of dust and dirt so they have to be fitted inside the vehicle.
The actual output performances of the 12 volt type should be treated with caution as the figures are very easy to fudge. Even if the identical setup is used on all the tested compressors the difference between them is not really noticeable.
If brand X take 10 minutes to inflate a tyre and brand Y takes 11 minutes, does that cause any great significance in the grand order of the universe?
The final consideration that has already been said is how often to you intend to use it. I subscribe to the theory, in this particular case any way, and that is, you only get what you pay for. A cheap compressor ceases to be cheep if you have to replace it one or more times.
