Cruise Control
Submitted: Monday, Jun 06, 2005 at 23:40
4X4Treker
I am going to install Cruise Control in my new GUIV Patrol and wondering if any one can recomend any particular brand and roughly what price I could expect to pay.
I am also going to modify the Auto Trans so that I can lock the converter manually and am looking for a steering wheel mounted switch as used in Cruise Control systems to adapt for this purpose, any ideas on where I might get one?
Treker
Reply By: Member - Paul P (Bris) - Monday, Jun 06, 2005 at 23:44
Treker
Ozcruise from Autron Autron Ozcruise . I have the fly by wire in my GU IV . Quite good. Looking around the $800.00 mark depending on options, supplied and fitted. I had the genuine Nissan Cruise switch fitted with
mine.
Paul
114704
Follow Up By: 4X4Treker - Monday, Jun 06, 2005 at 23:52
Thaks for that Paul
Treker
370534
Follow Up By: Leroy - Tuesday, Jun 07, 2005 at 08:46
I agree with Paul. I had the Command cable pull job that the dealer installed and it was a POS. It didn't keep the speed as
well on hills, was difficult to set, and when you set it it then cruised at 5kph slower than when you set it. After the dealer looking at it a couple of times they decided to put in an Autron. I (and them) have never looked back.
Leroy
370544
Reply By: Fusion - Tuesday, Jun 07, 2005 at 08:12
I 2nd what Paul said, Autron with genuine Nissan switches. I had it done at Motor One in
Brisbane:
42
Wyandra St
Newstead
QLD, 4006
Australia
Ph: (07) 3252 2788
Thanks,
Aaron.
114716
Reply By: Chaz - Tuesday, Jun 07, 2005 at 10:10
4X4Treker,
Sorry I can't help you out with your Cruise control or switches, but assuming your talking about a 3.0L diesel, this link may help you to install your manual lockup converter system.
Good luck
Chaz
114731
Reply By: angler - Wednesday, Jun 08, 2005 at 21:18
I agree, AUTRON is the best at the moment. There are a few lockup systems around and one that works in conjunct with the speedo. I am currently working on one that also uses the speedo to allow lockup above preset speeds and unlock below the preset.
Still in the experemental stages at the moment.
114959
Follow Up By: 4X4Treker - Thursday, Jun 09, 2005 at 22:26
Thanks for the advice about the Autron if you are looking at lock up on auto trans look at Chaz above on his link, he has designed a lock up that works
well (manual) and unlocks when you touch the brake pedal, I have driven his 4X4 GUIII and it works
well and I will be putting it into my new GUIV as soon as I get a chance. One of the advantages of Chaz's system is that it gives full engine breaking until you touch the brake pedal, great for when you tow.
370895
