clutch 1hz clutch flywheel
Submitted: Tuesday, Jun 07, 2005 at 16:39
ThreadID: 23667 Views:3235 Replies:2 FollowUps:0
Hi can the larger turbo diesel clutch bolt up to a non turbo 1hz flywheel? are there 2 different set of holes to mount the 2 different clutches? cheers polar
Reply By: crfan - Tuesday, Jun 07, 2005 at 16:49
Hi Polar dont know if they will bolt up or not the turbo and non turbo have fine splines and corse splins so the clutch plates are different .Why not use a R.P.M.
heavy duty clutch ?
Peter...
AnswerID: 114778
Reply By: Member - DOZER- Tuesday, Jun 07, 2005 at 22:31
The t/d flywheel has a 12 inch diameter clutch face and wider set threaded holes and is interchangeable on the crank of a 1hz...u needthe t/d flywheel to run a t/d clutch, 1hz flywheel has 10 inch plate surface, h/d available, from ARB but get the boosted 60 series master out!!!!
Also, machine any hot spots out of the flywheel or u will get shudder!!!
AnswerID: 114839
