GPS positions
Submitted: Friday, Jun 10, 2005 at 11:39
Willb
Hi, I have had a look at the archives and googled for this information but I must be wording my search incorrectly.
Where is a resource that lists GPS positions. eg
Cameron Corner,
Birdsville etc.
Any assistance is appreciated.
Will
Reply By: Member - Davoe (Widgiemooltha) - Friday, Jun 10, 2005 at 11:44
for those kind of locations I generally use............................... a map!
115224
Reply By: JohnN - Friday, Jun 10, 2005 at 11:54
Will
Try here, type in name and coords come up.
http://www.ga.gov.au/map/names/
JohnN
115225
Follow Up By: Member - Jeff M (WA) - Friday, Jun 10, 2005 at 14:03
Hey JohnN, that's pretty cool!
370974
Reply By: Nudenut - Friday, Jun 10, 2005 at 11:55
here ya go
115226
Reply By: Willb - Friday, Jun 10, 2005 at 12:08
Thank you, that is exactly what I was looking for.
Does any body produce maps with GPS markings on them.
Will
115230
Follow Up By: BenSpoon - Friday, Jun 10, 2005 at 12:33
I cant think of any decent maps I have seen that dont- Chances are it will just be a different datum to the one you are using in your GPS. Look in the extreme corners of the maps- It may be in a number of different formats- even Degrees, minutes and seconds can be plugged into a GPS- It doesnt neccasarily have to be a specific GPS datum.
Go through the menus in the GPS, and change your map datup to match the maps- that way theres no error on calculations to convert the values.
370958
Follow Up By: Pluto - Friday, Jun 10, 2005 at 14:27
Most of the recently published Hema Maps intended for the offroad community have the lat & long of many significnt locations printed on the map sheet.
Maps such as:
Great Desert Tracks
KimberleySimpson Desert
and others
370981
Reply By: Willb - Friday, Jun 10, 2005 at 12:40
Well I'll be stuffed, after BenSpoon's reply I had a look at my maps that came with my desert parks pass and there on the bottom is exactly what I was after.
So thank you to all that replied with constructive imput.
Will
115233
Follow Up By: Mike Harding - Friday, Jun 10, 2005 at 15:07
It sounds as if you're new to GPS and mapping? May I suggest you visit this site:
http://gpsinformation.net/
and follow some of the tutorials on the subject.
Mike Harding
370989
Reply By: Willb - Friday, Jun 10, 2005 at 17:07
Thanks for all the quick replies. And yes Mike I am new to GPS. I have purchased the Uniden GPS105 with
uhf radio and GPS. ( from prestige comms in WA. excellent price and service).
The info on GPS is a bit sketchy in the manual. Have only used it around the south of
Sydney so far.
So I am just trying things out.
I am going to
Cameron Corner,
Bore Track,
Haddon Corner and
Birdsville in July and was after a few GPS positions.
Will
115271
Follow Up By: Pluto - Friday, Jun 10, 2005 at 17:29
I would be interested to see how you go with the GPS105. Good points, bad points etc.
371009
Reply By: Glenno - Saturday, Jun 11, 2005 at 22:13
The UBD on disk also has coordinates. So if you are looking for more detailed locations, ie the local pub, hotel etc.
I have the 8 cities on CD and its awesome.
Glenn.
115387
