Leaded Fuel Additives - ATF
Submitted: Sunday, Jun 12, 2005 at 10:11
ThreadID: 23796 Views:2185 Replies:4 FollowUps:1
Hi Guys,
Has Any one ever heard of or used Automatic transmission Fluid As a fuel additive in unleaded petrol, replacing Leaded petrol or super? I have heard of a few people doing it and wondered whether it was worth while as ATF is cheaper than the flash lube that I use now
Reply By: Nudenut - Sunday, Jun 12, 2005 at 10:38
if your vehicle was intended to run on super, and you dont wish to retain forever (till you die) it may be more practical to run the thing on unleaded till it dies whilst budgeting to replace with unleaded vehicle.
AnswerID: 115422
Follow Up By: Exploder - Sunday, Jun 12, 2005 at 12:49
Yeah ATF fluid is basically hydraulic fluid, can’t see it mixing to well with petrol.
Premium with the lead substitute best way to go
If you really want to go el-budjo you could use kerosene, or stock up on avgas-100
FollowupID: 371126
Reply By: Member - RockyOne - Sunday, Jun 12, 2005 at 12:24
Forget about those little Flashlube packs the servos sell.The product is good,econ is not..I buy the 1 Litre bottle and add a plastic egg cup to ea tank of 50 litres..Even use it in my Wrangler as,if it lubes top end of "super" motor,it must help a "un-leaded motor" also..No motor ever died from over-lubrication. (Except of course,back when we used to add SAE-30 to our 2-strokes and plugs carboned up..Jawa/CZs,chainsaws etc)..BiTron fuel additive makes a motor mrun sweet also..Also only use a egg-cup of it per 50ltr and find it works well.Not "snake oil"..Got doubts..Use the "suck it and see" system..Try a tankful
AnswerID: 115435
Reply By: mattlobie - Monday, Jun 13, 2005 at 20:56
What sort of car do you have, bo-bo?
matt
AnswerID: 115591
Reply By: Bo-Bo - Wednesday, Jun 15, 2005 at 16:20
my car is a hx holden ute with a 202 red motor today I have filled it up with normal unleaded and added the atf just like I would flash lube so we shall see
AnswerID: 115890
