Kitchen Unit
Submitted: Saturday, Jun 18, 2005 at 17:42
Rickoshay
Hi all,
Wondering if anyone can help. I've got a Cameron Off Road camper and would like to build 2 x slide out draw/kitchen units (1 each side pull out the back) size about 400x400x1750. I am struggling with keeping weight down ( have contemplated steel box frame and 10mm ply) and yet still strong enough to handle rough stuff. Also does anyone have any ideas about cheapest and easiest method of slide assembly, so as the BOSS can pull out the unit also?
Thanks.
Reply By: Member - Anni M (SA) - Saturday, Jun 18, 2005 at 17:51
Hi Rick
I am no expert on building such things, so I can't be much help that way. However, I wondered if you had considered other options. Our Challenge CT has the kitchen mounted on the rear
gate. It is really easy to use and has been the envy of many people with pullout kitchens. It is made of steel, and has a Spinflo 2burner gas stove/grill, a sink and plenty of storage space. It is brilliant to be able to stop for a cuppa, open the kitchen and away you go. Ours is also an offroad trailer, and we've given it a fair beating without any problem. It also leaves heaps more space in the trailer for other things!
Hope these ideas are a help.
Happy travels
Anni
116257
Reply By: AT4WD ADVENTURES - Saturday, Jun 18, 2005 at 18:34
Hi Rickoshay,
What is your location?
Stuart
116267
Follow Up By: Rickoshay - Sunday, Jun 19, 2005 at 18:10
Stuart,
East Gippsland. Vic
371903
Reply By: Member - Stan (VIC) - Saturday, Jun 18, 2005 at 19:01
Reply By: jon p qld - Saturday, Jun 18, 2005 at 21:36
I have the same cameron c/t as you with the genuine cameron kitchen box. It's made of 5ply and slides out the back on two nylon runners. It's big enough for all our kitchen gear and easy to pull out. I've had it with the trailer for five years and it's never caused a problem. I'm sure if you built one to your own design using the same materials you would find it light enough and strong enough for the job
regards Jon
116294
Reply By: time waster - Sunday, Jun 19, 2005 at 08:42
hi i have built what you are after in our c/t out of 7mm ply its not too heavy but as you have so much more usable space she really fills it up if you send me your email address i can send some photos
116319
Follow Up By: Rickoshay - Sunday, Jun 19, 2005 at 18:08
time waster,
thanks for reply.
try seabirdsea@bigpond.com
371902
