Leak in Windscreen washer
Submitted: Tuesday, Nov 19, 2002 at 01:00
Member - Bob
Ok you bush mechanics it's not as critical as a radiator, but it is very annoying: leak at base of windscreen washer resevoir. Tried repairing with Araldite but this left a microscopic hole which is enough to allow contents to drip out over a day or so. I was wondering if the was a rubberised compound I could pour in and swish around the base, or something like Superglue that would run into the minute cracks? The pump and 'low level' warning switch attach through rubber gaskets and are easily removed. Any one had any success with similar problem and know of a good product?
Reply By: OziExplorer - Tuesday, Nov 19, 2002 at 01:00
Buy a new one as they are normally pretty cheap. Otherwise remove it and get it welded. No glue to my knowledge sticks to polyethylene.
8691
Follow Up By: Truckster - Tuesday, Nov 19, 2002 at 01:00
Windscreen washer bottle for GQ around $95 cost....
Same as Radiator overflow bottle...
Aint cheap!!!
and rare as rocking horse poo at wreckers.
4243
Reply By: Goran - Tuesday, Nov 19, 2002 at 01:00
Try silastic mate. It just may work.
8696
Reply By: rodeoowner - Tuesday, Nov 19, 2002 at 01:00
I smeared silicone over
mine when it baegan to leak. That was about 18 months ago and it hasn't leaked since.
8698
Reply By: Member - Bob - Tuesday, Nov 19, 2002 at 01:00
I thought it was going to cost an arm and a leg but they are $60 new so while I hate turfing things that can be fixed I can't afford to mess around any longer. A new one it is.
8702
