Help with rig pic
Submitted: Tuesday, Jun 21, 2005 at 11:05
Member - Poppy (QLD)
Hi all
Trying to post my rig pic and I think I made it too small, my question is how do I remove it?
Cheers Poppy
Reply By: Member - iMusty (VIC) - Tuesday, Jun 21, 2005 at 11:14
You delete all you text in the description section and start again.
116678
Follow Up By: Member - iMusty (VIC) - Tuesday, Jun 21, 2005 at 11:16
When I say "descroption" I mean signature...
372179
btw do you like my new one?
372180
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jun 21, 2005 at 16:57
iM it helps to read the question doesn't it.?
372227
Follow Up By: Member - iMusty (VIC) - Tuesday, Jun 21, 2005 at 17:19
John & Moses
Yes indeed. I was so excited bescuse I thought that "I" could offer assistance to someone so soon after the post that I did NOT help afterall.
lolololoollol
iMusty.
BTW it took me ages to work out what "iM" meant. lolol
372232
Reply By: Member - iMusty (VIC) - Tuesday, Jun 21, 2005 at 11:20
So that's
My Home
- My profile
- My signature
116682
Reply By: Member - iMusty (VIC) - Tuesday, Jun 21, 2005 at 11:24
Reading your question again it could mean you want to remove it from your stash of pice. Then just click updatr and search for a new pic...
116683
Follow Up By: Member - Poppy (QLD) - Tuesday, Jun 21, 2005 at 11:35
You got it,
I am just trying to resize the pic and will try again
372184
Reply By: Al & Mrs Al (Vic) - Tuesday, Jun 21, 2005 at 13:44
Poppy,
do you have a thumbnails program, you can download some for free, try a search for "easy thumbnails" in google, you should find one there. Once you've uploaded a new pic,hit refresh and you should see the new pic there provided it's not too big.
and to see your pic,you must have a signature...good luck
Lyn
116714
Follow Up By: Member - Poppy (QLD) - Tuesday, Jun 21, 2005 at 20:48
Thanks Lyn
Found a thumbnail program so will try again
Cheers Poppy
372259
Reply By: Troopy Travellers (NSW) - Tuesday, Jun 21, 2005 at 19:43
ROFL, I thought picture what picture and then I went to check your rig etc and there it was, if you have problems mem message me and I could email it back to you the correct size. Carolyn
116774
Follow Up By: Member - Poppy (QLD) - Tuesday, Jun 21, 2005 at 20:51
Hi Carolyn
I am a bit of a newby at posting pics etc, but learning slowly
Thanks for the offer anyway
Cheers Poppy
372260
Follow Up By: Troopy Travellers (NSW) - Wednesday, Jun 22, 2005 at 08:15
I think its great too but just a tad dark, I put it through the Shadows/Highlights filter in Photoshop CS. Have attached it here you should be able to right click it and "save as" if you like it.
!MPG:12!
372300
Reply By: Lone Wolf - Tuesday, Jun 21, 2005 at 20:03
That is one cool picture!!
116779
Reply By: Sand Man (SA) - Wednesday, Jun 22, 2005 at 01:24
Poppy,
Seeing that you want to replace an existing photo with a new one, you don't have to delete the old one first.
Just select
My Home - My Rig and click on the Upload button. This will allow you to specify the location of the new photo you wish to load.
Finally, click Update to make your change permanent.
If you make your picture size about 300 pixels, you should end up with a good sized photo that is under the 50k maximum.
116827
Follow Up By: Member - Poppy (QLD) - Wednesday, Jun 22, 2005 at 14:09
Thanks Sandman
Managed to update ok, just getting some lessons on how to resize to 300 pixels, like I said earlier, I am a bit of a newby at this stuff.
Cheers Poppy
372372
