Charger for a Deep Cycle Battery
Submitted: Tuesday, Jun 21, 2005 at 17:27
Pedirka
Hi everyone.
Just bought a 105 amp/hr Deep cycle battery for the camper to last a long weekend here and there.I was planning on just charging it at home before we go off. But It occurred to me that perhaps a particular type of 240v charger is required. I dont want to spend too much on a charger as Im going to see if I can charge from the vehicle at a later stage (another post?).Can anyone give me some advise before I purchase the wrong charger.
Thanks heaps
Tony (Pedirka)
Sunny Qld
Reply By: Glenno - Tuesday, Jun 21, 2005 at 17:59
You will need to purchase a 3 stage charger. I use a 3.5A/hr charger, so that would take 15hours to charge it up from half capacity (for example). If that is OK for you then you can buy them for a good price from battery shops, Jaycar, dick Smith etc.
I run a similar setup to you with a 130A/hr battery and a 3.5A/h charger. The 4wd alternator does a good job of keeping charge in the battery, but the 3 stage charger brings it right up to fully charged before each trip.
Search the archives heaps of other thoughts on this exact topic.
Glenn.
116754
Follow Up By: Member - Jeff M (WA) - Tuesday, Jun 21, 2005 at 18:33
Glenno, just interested in the brand, type and size of your 130amp/hr, I'm looking at upgrading to that kind of size but am worried about:
a) heat
b) pysical size
As it's got to go under the bonnet where the existing N70ZZ 80Amp/hr is.
I'm just drawing tooooo much juice now days and I'm killing the 80 overnight.
372244
Follow Up By: Glenno - Tuesday, Jun 21, 2005 at 21:32
Its a trogan battery model SCS225
Go to the Trogan Website -> Trogan Website
Click
Recreation Vehicle then SCS225.
Not cheap but works fine. Doesnt use any
water that ive noticed which is a welcome change from the Century I used before.
Glenn
372268
Follow Up By: Member - Jeff M (WA) - Wednesday, Jun 22, 2005 at 11:07
Thanks Glenno, you know that's what I thought it must have been as I havn't seen any others in that capacity that would fit in a vehicle. My power crank eats
water for breakfast, but my engine bay does get a little on the HOTside.
Well a lot on the hot side...
I've been looking at the Trogan because of the small physical size vs large capacity but the only place I know of that sells them is the 12 volt
shop and they are a little rediculous on price... (on most things, not just batteries).
372320
Follow Up By: Glenno - Wednesday, Jun 22, 2005 at 15:39
Their website lists the distributors in each state. I purchased
mine from Turbo Batteries in Brendale in
Brisbane, but there are quite a few outlets in each state from memory.
Glenn.
372399
Reply By: Trekkie - Tuesday, Jun 21, 2005 at 19:39
I have a
Kimberley Kamper - Came standard with Deep Cycle Gel Batteries and a Battery charger fitted - its a Xantrex TC10 - Microprocessor controlled with 3 step charging as referred to above. I have done some lengthy trips just using the Rotronics (in the car) to charge it for up to 5 to 7 days and then plugging in 240 volts when the opportunity presents. When we first got the setup, I used to run the Gen Set almost every night, but found that really not necessary. It runds a BIG Autofridge and lights - never had a problem
116773
Follow Up By: Trekkie - Tuesday, Jun 21, 2005 at 19:44
Sorry, forgot to give the web site www.xantrex.com
link text
372254
Follow Up By: Mainey (WA) - Tuesday, Jun 21, 2005 at 22:53
Trekkie,
The reason your battery charger works so
well is the specifications meet the requirements of Deep Cycle batteries, with a current output of 10 Amp at 13.8 to 14.8volt and a float charge of 13.1 to 14.2volt and with the benefit of three weekly boost charge facility.
It is a purpose built three stage battery charger, not a cheap imitation. (yes it can also be used for starter batteries)
And the Rotronics in the vehicle keeps the DC battery charged while you are traveling!
372285
Reply By: Member - Paul P (Bris) - Tuesday, Jun 21, 2005 at 19:50
Tony
Go here Absorbed Power . Good gear and good to deal with.
Paul
116775
Follow Up By: Member - John Q (QLD) - Tuesday, Jun 21, 2005 at 20:51
Hi Paul,
Thanks for that link. They are nearby & will check there battery products.
372261
Reply By: Neville M (VIC - Melb) - Wednesday, Jun 22, 2005 at 08:40
After a Good Battery, Solar panel/reg, etc, try this on line site.
www.solaronline.com.au
They are in
Sydney and give great advice over the phone, better than any
shop I have been to.
116845
Reply By: Pedirka - Wednesday, Jun 22, 2005 at 10:47
Thanks everyone for your feedback and links to other sites and info.
I am now much better informed. 3 stage chargers are the go I believe.
I would have wasted my doe on one of those cheapy chargers and not got 100% out of the battery and due to being unable to fully charge, the battery would have started to lose capacity and die earlier.
Thanks again
Tony (Pedirka)
Sunny Qld
116861
Reply By: Member - Collyn R (WA) - Wednesday, Jun 22, 2005 at 17:37
When comparing charger costs bear in mind that a genuine three-stage battery charger will bring a battery up close to 100% charge (from say 40%) in about half the time that a conventional charger will take to reach 70%.
Its hard to give absolutes but a good 7.5 amp three-stage charger is likely to do much the same as 20-amp chainstore device - excepting only the former will fully charge a conventional battery.
Collyn Rivers
116926
