Oil filters
Submitted: Tuesday, Jul 05, 2005 at 21:57
york
Posted At: Friday, 1 July 2005 6:12 PM
Posted To: ExplorOz
Conversation: FeedBack from ExplorOz.com
Subject: FeedBack from ExplorOz.com
My Toyota landcruiser (Diesel) has an extra external oil filter canister fitted. It is marked 'Filter 2000 Pty Ltd" and this model fits two cartidges. I use to buy them from an agent in Belmont WA, however they moved and I can not find them. Does anyone know where these filters are available from in WA. I understand the same company markes fuel filter that work in a simular way - external canister with removable filter.
I understand they are made in Australia and also used on earthmoving equipment as you can couple the cannisters together to make the system use 6 or 8 or more filters to once
Phone/Fax 08-96411714
MailList: on
Reply By: 120scruiser - Wednesday, Jul 06, 2005 at 09:50
Sounds like fleetguard or CAV.
Do a google and see what you can find. Bear in mind CAV are now owned by Delphi.
119068
Follow Up By: york - Monday, Jul 11, 2005 at 22:35
Thanks to all who answered my query about oil filter.
The company is now known as Filtertechnology Australia and I found their agents in
Perth.
Great helpline - thanks
374934
Reply By: Member - Roachie (SA) - Wednesday, Jul 06, 2005 at 11:51
To me it sounds like a form of by-pass filtering. I have recently fitted an AMSOIL dual-head unit to my Patrol so that oil is filtered to much finer tolerences (less than 1 micron whereas standard filters are good to about 20 microns). This involved the removal of one of the standard filters (the Patrol has 2 normally anyway) and replacing it with a screw-on fitting with 2 hoses running off to the remote head unit. The remote head has 2 filters, one large (by-pass) filter and the other one is effectively there to do the job of the one I removed from the block.
I'm not sure what the thread sizes are on your head unit, but you may possibly be able to use AMSOIL filters instead of the others if you can't get hold of any.
Hope this helps.
Roachie
119095
Reply By: Flash - Wednesday, Jul 06, 2005 at 20:13
Yep, Bypass filter it is.
Filter 2000 were made by
Filter Technology. Replacement elements are freely available.
ter Technology</a
119162
Reply By: Brian - Thursday, Jul 07, 2005 at 02:06
My brother is an expert on this bypass filter business and has some connection with the WA mob who sell them , give me a day or so and i will get back to you
119217
