New Camp Ovens
Submitted: Friday, Jul 15, 2005 at 19:55
Gerhardp1
I have just acquired a couple of new cast iron
camp ovens and need to get them ready for use.
Can anyone advise what to do.
Gerhard
Reply By: Andy C - Friday, Jul 15, 2005 at 20:04
Canola spray (
well soaked before first use) and then always pack away "after" spraying - never any rust and always ready to go!
Andy
120546
Reply By: Member - Jimbo (VIC) - Friday, Jul 15, 2005 at 20:19
Gerhard,
Wash them, dry them (on a warm oven), coat them inside and out librerally with oil, let them sit overnight to absorb the oil. Wipe them down and put them in a hot oven until they smoke and go black.
After that they will never rust. You have sealed the iron and can then use them and happily wash them out using detergent. Every time you
cook in it you will add some fat to it, to help the coating inside.
After doing a roast make gravy with the juices left. After you have used the gravy, add plenty of
water and let it boil on the fire (the following day is fine if you don't want to do it after tea). Tip that out, add some more
water with detergent and let it boil again, and whilst it is boiling scour it with a metal pad and tongs. Then tip out the
water and flush with clean
water. Pop it back on the fire to ensure it is completely dry.
Take it off the fire, let it cool and brush down the outside.
Sounds a bit involved, but it takes bugger all time. You are actually letting the fire and
water do all the work.
Be wary of the opinion "never put detergent in a
camp oven". It is a myth. My el cheapo cast iron job is 15 years old, rust free and sparklingly clean.
Jim
120549
Follow Up By: Diamond (Vic) - Friday, Jul 15, 2005 at 22:02
water.
.and where would one dispose of this
water with detergent?
375672
Follow Up By: Member - Jimbo (VIC) - Saturday, Jul 16, 2005 at 08:58
ROFLMAO
375703
Reply By: Member - Norm C (QLD) - Friday, Jul 15, 2005 at 20:24
Do a Google and you'll find more info than you can use.
The must be
well seasoned before use.
Give it a good scrub with hot soapy
water. This should be the last time you put soap on it, although some people use soap, just make sure you get it all off with very hot
water and re-oil.
Rub heaps of vegetable oil on it (must not have animal fat or it will go rancid). I use olive oil. Heat it in the oven (about 200 to 250 degrees) for 15 to 20 mins. Repeat 2 or 3 times if you want a really good job, but not essential. Don't open the oven while it is in there or you will smoke the house out.
You can do it on the barbecue or an open fire if you prefer.
Apply another thin coat of oil before storage.
You should end up with a deep brown to black oven. It will be near non stick and should just need a good soak, scrape out and wipe over to get it clean after use.
Keep it oiled and in a cloth bag. Wife made a great draw string bag for ours. Keeps it clean and stops oil getting on other stuff in the 4B.
If it ever gets rusty (shouldn't if you season it right), you will have to scrub it out and season again.
Don't
cook in it without seasoning. The food will taste terrible.
120552
Reply By: Member - Davoe (Widgiemooltha) - Friday, Jul 15, 2005 at 21:57
If they are decent
camp ovens did they not come with instructions on them? I would follow that
120574
Follow Up By: Gerhardp1 - Friday, Jul 15, 2005 at 22:32
Thanks for this helpful info. If you can't help, don't speak.
375679
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Jul 16, 2005 at 00:33
I dont understand the aggresion it was a reasnable reply. I recently bought a
camp oven and it had the instructions on the label. If I was at home I would have copied them into the reply
375693
Follow Up By: Gerhardp1 - Saturday, Jul 16, 2005 at 09:15
Your reply suggested either
that the ovens I have aren't decent (because they have no instructions)
or
I'm stupid for not reading the label that did come with them.
Both these suggestions are agressive from my perspective end and received an appropriate reply.
Gerhard
375705
Follow Up By: Member - Luxoluk - Saturday, Jul 16, 2005 at 18:31
Hi Davoe
Yeah.. I can relate to your comment. I bought a Furphy
camp oven up in Shepparton recently...been on my list for years. Came with good instructions on how to season it and even a few recepies too boot! I'm with you on this...and not snooty at all!! Cheers
375769
Follow Up By: Member - Pezza (QLD) - Saturday, Jul 16, 2005 at 22:11
Am with you Davoe, ours came with destructions as
well, thought the aggression and attitude started in follow-up 375679.
Now where'd I leave that packet of chill pills.....?
Avagoodn
Pezza
375785
Follow Up By: Eric from Cape York Connections - Sunday, Jul 17, 2005 at 07:37
I have 3
camp ovens and they came with instiuctions.
I did a four week crash corse in chinese and now its as clear as mud.
All the best
Eric
375809
Reply By: Gerhardp1 - Friday, Jul 15, 2005 at 22:31
Thanks for all the info.
I think I will do the initial heating cycles in the Weber so that I don't fill the kitchen with smoke!
I have a great cast iron frypan that has served
well for over 30 years but I couldn't remember how I conditioned it (must be due to the alzheimer's setting in ......)
Gerhard
120586
Follow Up By: Eric from Cape York Connections - Sunday, Jul 17, 2005 at 07:39
I think thats a good idea.
Give it a good wash.
Then use a spay oil in and out.
Then I put
mine in a bag.
All the best
Eric
375810
