Pajero Dual Batteries ??
Submitted: Sunday, Jul 17, 2005 at 09:49
Rosco - Bris.
A mate of
mine and his partner have a 94/95 ? Pajero.
Anyone with a similar vehicle who has installed an aux batt ?? They are keen to do so, so I figure I'll ask those who've been there/done that.
Ta in advance
Reply By: Rosco - Bris. - Sunday, Jul 17, 2005 at 09:57
P.S.
They are also considering a 2nd hand 50l Waeco, asking price $750. My thoughts are that that's a bit steep, what do you troops reckon ??
Ta
120747
Follow Up By: Time - Sunday, Jul 17, 2005 at 10:14
Fridge price is way over the top. I paid $650 2 years ago on a special deal for one.......tell 'em their dreaming!
Time
375820
Follow Up By: Rosco - Bris. - Sunday, Jul 17, 2005 at 11:11
Yep ... they're dreamin !!
375831
Reply By: Terryfirma - Sunday, Jul 17, 2005 at 10:40
3.0lt Petrol or Diesel.? I have installed a second battery in a 93 3.0lt petrol. Relatively straight forward job. Can supply photos if required.
Regards Terry
120750
Follow Up By: Rosco - Bris. - Sunday, Jul 17, 2005 at 10:47
Thanks Terry, that would be ex. It's a petrol model.
My email address is in my stats.
375826
Reply By: Bob of KAOS - Sunday, Jul 17, 2005 at 13:58
I had the auxiliary battery in the Paj of that vintage. I recall I had to relocate the cruise control unit and the fuel vapour canister so it would fit in the left side of the engine bay.
120775
Reply By: peteC - Sunday, Jul 17, 2005 at 18:09
I fitted one to my 94 Triton Diesel and it was a piece of cake. Spend the money and get a battery holder from ARB or similar. If the Pajero is the same as the Triton There is a Fusable link box under the bonnet. Cut the link in the box to separate the lights, aux etc and wire your aux battery into the parts of the car you want. Install a solenoid that operates off your ignition and wire the alternater and main battery off one side and the aux battery on the other. The trick is to get a timer that will run for 30 seconds to stop the solenoid from activating while you start the car. I had one so the whole excercise cost me a battery, solenoid $60 and a battery holder $90. I have ( or should I say the kids have after turning my lights on while it was in the garage ) flattend the battery fully and had no issues starting the car.
120799
Reply By: bomba - Tuesday, Jul 26, 2005 at 21:06
Have had 92 pajero, 95 pajero and now 97 Pajero. All have had dual Batteries fitted. 92 & 95 had no cruise control and was quite simple. Battery box to suit is available from 4wd shops with only two holes to drill and will take a N70Z Battery. Battery box about $130. Had to move the carbon canister to the drivers side. With the 97 NL 3.5 litre the battery tray only just clears the cruise control, however a N70Z battery will not clear the fuel lines. A suitable battery for this is a N50Z, which is about 25mm shorter than the N70Z. All my vehicles were fitted with a manual switching device which I have found to be more reliable and less hassle that a automatic setup.
122187
Follow Up By: Rosco - Bris. - Tuesday, Jul 26, 2005 at 21:35
Thanks for the info Bomba. I'll pass it on
Rosco
377368
Follow Up By: Sapper - Monday, Aug 08, 2005 at 18:25
I do not use a second battery. I upgraded the main to a 700 CCA and use a power pack in the rear. Never had a problem to this day.
Mineclearer
379241
