GLIND SHOWER shower head problems or not
Submitted: Sunday, Jul 17, 2005 at 17:16
GREENDOG
Having problems with the shower,it seem's to flow ok with out the shower head connected to the hose but as soon as i connect it back on i get a flow as if there is an air suckin in from the head but i've check it out it's fine ,has any one else had this problem or not cheer's GREENDOG
Reply By: peteC - Sunday, Jul 17, 2005 at 17:51
I have one on my Triton, and the problem is that the pump is reaching full pressure then auto switching off ( like it is meant to do when you turn the tap off ). If you use too large diameter or a too short hose prior to the pump on the intake it will do the same thing. I use a longer hose made of the clear tubing from a hardware store about 10-15mm on the intake and it works
well as the intake and output must balance out. Experiment with a tap on your inlet and restrict the flow and you should see what I mean
120794
Follow Up By: GREENDOG - Sunday, Jul 17, 2005 at 19:17
Thanks pete i'll have a play around with it during the week,sounds positive cheer's GREENDOG
375871
Follow Up By: Tony F - Monday, Jul 18, 2005 at 18:55
If you simply use 12mm hose ( garden hose or heater hose, more flexible)for inlet and /or outlet you shouldn't have a problem. We run a hose length from 1m up to 10+m without any problems. As PeteC said, it's all about balance. If the pump flicks on for a second or two with the shower head turned off, you have air entering the system and you need to check all your conections. Happy
Camping.
376036
Reply By: D-Jack - Monday, Jul 18, 2005 at 01:18
Lovin' that rig picture now. You can tell what sort of car it is!
120868
Follow Up By: GREENDOG - Monday, Jul 18, 2005 at 10:18
Thanks D-jack I'm tryin to work it out
375956
