L/C 100 sub tank light
Submitted: Monday, Jul 18, 2005 at 21:25
Seto
Hi all,
I have a problem when I switch to my sub
tank that the SUB light doesn't come on. I have already checked the globe in the instrument cluster and it is fine. Has anyone any suggestions or knowledge of any common failures in this area?
David
Reply By: Paul.S - Monday, Jul 18, 2005 at 21:35
Hi Seto,
If it a current IFS model its is a comon problem. My 2003 failed last year. It actually still switches to the sub
tank but you cannot tell. To fix the problem you need to replace instrument cluster. If the car is still under warranty Toyota will replace it no charge. If no warranty get ready for big $$$. But once changed they have not had any more fail.
Paul
121027
Follow Up By: Seto - Thursday, Jul 21, 2005 at 14:30
Thanks for the response Paul - it isn't an IFS. Yes everything works with the switch except the light and no it's no longer under warranty so I guess I will either get used to it or rig up a separate light.
David.
376560
Reply By: Vic - Monday, Jul 18, 2005 at 22:48
Hi David,
Yep, I agree, this is a common problem - happened to me - pi$$ed of the wife when she was running on an empty
tank with a full indication!
Took the dealer about 2 weeks to get the instrument cluster in, then another couple to send it to the doctor to have the current K's wound on.
No problems since, although voltmeter seems to sit a bit lower, just under 1/2 way, 14V from memory, on this set of instruments.
Good luck, hope it's warranty.
Vic
121038
Follow Up By: Seto - Thursday, Jul 21, 2005 at 14:31
Thanks Vic - not warranty oh
well - bugger....
David
376561
Reply By: muzzgit (WA) - Tuesday, Jul 19, 2005 at 01:15
Yep, that's it, it's buggered.
Better get rid of it and get another one. te he
Only joking.
121048
