GQ Patrol 4.2 EFI Fuel Pick Up
Submitted: Tuesday, Jul 19, 2005 at 18:15
cloughie
On a recent trip to the
Kimberley, the above vehicle when off road gave all the indications that it had run out of fuel when the guage showed it still had at least a third of a
tank left.On the second occasion i twigged to the problem and put a jerry of fuel in and it fixed the problem. We continued our journey ensuring we kept the fuel level up. Once we were back on the bitumen the problem did not re-occur and we ran the vehicle to below a quarter before refuelling. The other thing I noticed when it was playing up was the fuel pump was making a strange noise and when I removed the fuel cap there was a tremendous whoosh of air. The strange noise i think was the pump sucking air and causing a vacuum in the
tank. Any answers from all the GQ experts out there.
Reply By: Truckster (Vic) - Tuesday, Jul 19, 2005 at 21:24
If when you removed the fuel cap it sucked in air, your breather is bloked.. it cant suck in air to replace the fuel its used out of the
tank.
I have had a similar issue when I fitted a LRT, it wouldnt work with 1/4
tank, it would run out.... thats with the modified pickup. I gave up
121211
Reply By: mechpete - Tuesday, Jul 26, 2005 at 23:10
Hi cloughie,
just read ya article on fuel pickup GQ4.2 efi ,I have one myself and I also have a 145lt LRA
tank and it uses the original
tank sender/pump assembly . Have just returned from the
Canning Stock Route ( excellent trip ) the vehicle has also
crossed the Simpson ,the
Gibb River Rd & a few other trips &
mine will run
until it runs almost dry, the sucking noise is OK its the way the Evap emission system works,the only trouble I,ve had is the fuel pump lost some pressure and it was hard to start when cold only ,been ok since replaced it . By the way auto trans is sensational in both High Country and Desert Country, 2nd GQ auto I,ve
had bit hard on fuel !! but there still making the stuff
Cheers mechpete Shepp.
122220
