GU Patrol 2.8
Submitted: Thursday, Nov 28, 2002 at 01:00
peter
Can any owners or ex owners of a GU 2.8 Turbo diesel patrol give me some info on their performance,reliabilityand economy as may consider buying one in the near future.
Reply By: Truckster - Thursday, Nov 28, 2002 at 01:00
Performance non existant
reliability good
economy very poor...
Dont... Get the 3.0 or 4.2
2.8 is bad joke. thats why they are cheap
9091
Follow Up By: Peter - Sunday, Dec 01, 2002 at 01:00
Thanks for the info on the 2.8 Patrol,bank account won't stretch to the 4.2 or 3.0 lt. Worst luck.
Regards Peter.
4596
Reply By: Goodsy - Friday, Nov 29, 2002 at 01:00
If you carn't afford the 3 or 4.2 GU's the 2.8 is not that bad. But it depends what you're going to use if for. A 2.8 is going to strugle with a 2 ton trailer. But around town and the occational trip into the bush and there good value.
9099
Yes thats what I've heard that they can struggle at times,was also considering a 4.5lt petrol but the economy becames the problem then.
Thanks for the info.
Regards Peter.
4597
Reply By: John - Friday, Nov 29, 2002 at 01:00
Reliabilty - it's a Nissan
Economy - 11-13l/100km what's wrong with that?
Performance - Towing under a tonne, no worries. Use 1st gear offroad where everyone else is using 2nd. Will go everywhere a 3.0 and 4.2 will go. People are never happy. How many 3.0 owners want to use powerup chips, how many 4.2 owners install a turbo. Yes the 2.8 is a compromise but still a good truck. Buy what you can afford.
9111
Thanks for the info on the 2.8lt Patrol.
Regards Peter.
4598
Reply By: Chel - Friday, Nov 29, 2002 at 01:00
Were the owners of a GU 2.8 TD.Wagon. Yes it is one of the cheaper ones but it was our first 4x4. We bought what we could afford and for what we had planned for it.Our vehicle does a minimum of 100klm per day and that is taking the kids to bus(all dirt) We have done a number of trips to NT,SA,QLD, 80% of these trips were off road. We tow a
camping trailer with a weight of around 1.2 tons. Yes it is slow on the uptake but we expect that. Are we disapointed with it? NO. We came into this vehicle after owning a 5litre commodore. We get around 650 - 700klm per
tank (95litre)no trailer or about 550-600klm per
tank with trailer. It has never broken down or given us any trouble whatsoever, so reliability is excellent.Hope this helps Email me if you want any more information
Regard
Chel
9123
Thanks Chel for the info on your 2.8lt Patrol,sounds like you are more than happy with yours,do you know of any areas of the vehicle I should pay particular attention to when inspecting a vehicle to purchase.
Was at one stage considering purchasing a 4.5lt petrol but the economy scared me off.
Regards Peter.
4599
Reply By: Steve Mc - Saturday, Nov 30, 2002 at 01:00
Pete We are on our 6th Nissan Patrol, & ours is a 2.8 Gu all the others were 4.2 diesels, the turbo 4.2 wasn,t available when bought ours back in 99. And I cant knock it, a tad slow on take off when loaded up,just use 4WL more often when off-road its done 138000 Ks not one problem,fitted a new timing belt as recomended at 100,000 and the car has been everywhere & I mean everywhere towing our Track Trailer , fuel economy towing the trailer is about 19-20mpg weighs about 1.2 t, at 110kph. All Ive had done is the fuel pump removed & timed up and injector break pressures evened up this made a lot of difference . All in all a great little motor that drags around a 2.3 tonne car. Hope this helps in your decision.
P.S They loved to be revved up, and will go anywhere the 4.2 Goes?
9145
Thanks Steve for the info on the 2.8lt Patrol,sounds like you are having a good run with yours.
My next option from the 2.8lt was the 4.5lt petrol but I tow a small van and Ithink the economy would send me broke.
When looking at a 2.8lt to purchase is there any particular areas of the vehicle that need closer inspection.
regards Peter.
4601
Reply By: Chel - Sunday, Dec 01, 2002 at 01:00
Just a follow up on the follow up. One area I have heard of to look out for is the gear box in 5th gear. Mainly from improper use, ie. using 5th around town.We do it's routine manual service,oil change every 5000klms, timing belt done at 100,000klm. Ours has now done 170,000klm. Before we bought ours we looked into its background(not always easy) and found out who owned it and what they used the vehicle for.Good luck
9172
Reply By: Cobra - Sunday, Dec 01, 2002 at 01:00
Peter,
I have a 99 2.8 GU tdi and am happy with it. It does have some limitations (does not take off from a standing start like a Maserati), may need to be 1-2 gears lower than a 4.2 at times and has a tendency to 'kangaroo' on steep, rocky uphill low range climbs but hey, accept the foibles and drive accordingly. It has been a very reliable vehicle so far and has returned a yearly average of 11-13l/100k. On a long blacktop run, refuel is usually 5l less than the 4.2's with us. Currently, it has 76k on the clock of which 90% is bush work as it is rarely used around town.
9183
Reply By: desert - Monday, Dec 02, 2002 at 01:00
Peter, the most often heard critisim of the 2.8 engine is it's lack of low end torque. It likes to rev and needs to stay over 2000rpm for the engine to begin making real power. They respond very
well to an after market power up (eg, Motson's) which is money
well spent. This will transform the engine from a slug to a reasonable performer. Economy on highway is excellent. Be aware that in hard 4x4 or towing situations, this little engine can consume as much as the 4.2 litre. One area to be cautious about is the gearbox. It is a light-duty box stolen from the 300ZX
sedan and as such it's construction was never intended for heavy duty 4x4 cycles. Fifth gear in particular is prone to failure if towing heavy loads. By heavy I mean tandem car trailers, large caravans and horse floats. Garden variety 6x4 box trailers are OK. Be warned. Provided the injectors are in spec, and a power upgrade along with a tune to dyno optimum results, then it will easily keep up with the bigger engined cousins, albeit with more revs on the tacho.
Cheers.
9210
Reply By: mike - Thursday, Dec 05, 2002 at 01:00
peter,
i have a 1996 gq with 2.8td, done 320,000 ks mostlly off tarmac
its been serviced every 5000 (oil, filter at 10000)
cam belt must be done at 100thou so if you buy one get it done if you dont when it was last done - cost $46 at auto traders for a good one
performance is not what you buy them for, good economy - we have just come back from a 6000 k trip with 2 adults 3 kids and all
camping gear in the back got 12lts per 100ks
the 2.8 seems more reliable than 3.0td - there are quite a few people who post problems with 3.0 injector pump
just make sure whatever you buy has been serviced properly
regards
mike
9343
Follow Up By: Truckster - Thursday, Dec 05, 2002 at 01:00
regards
mike
COULDNT AGREE MORE... When you buy a second hand anything CHANGE ALL TH' FILTERS AND FLUIDS.... Cheap insurance and you can keep track of it all then
4733
