Camping hot water service
Submitted: Wednesday, Jul 20, 2005 at 01:23
Mattbrook
Hi All,
Just a question regarding how to make a
camp hot
water service. When I was in scouts(many moons ago!) we used to have a hot
water service that used to sit on the edge of the fire place. Would anybody out there know how to make one of these? As I remember(correct me if I am wrong) it was made with a 20ltr steel drum. Thanks for any help.
Matt Brook
Reply By: Rosco - Bris. - Wednesday, Jul 20, 2005 at 07:50
G'day Matt
See if you can get your hands on an old 5 gal beer keg. Best by far, stainless so lasts forever.
You'll need a pipe and male threaded bung for the tap hole. Weld a plate over the original filler point .... you'll find it's down on the opposite side to the tap hole so no good.
Get a piece of stainless pipe welded through a new hole adjacent to the bung hole. This pipe should extend about 20mm outside the keg and be long enough to go inside to within about 20mm of the opposite inside.
Now make up a cradle so the keg can lie on it's side with the tap hole at the top along with the new filler hole.
When it's full of hot
water, simply pour more cold
water in through the filler hole using a bucket and funnel. This goes down the pipe to the bottom of the keg, displacing the hot
water and forcing it out the spout.
Same principle as a storage hot
water system.
121249
Follow Up By: Mattbrook - Wednesday, Jul 20, 2005 at 13:38
Thanks for your help Rosco. Much Appreciated.
Matt
376358
